Old 10-02-2018, 08:50 PM   #1
cgg17
cgg17 is just really nicecgg17 is just really nicecgg17 is just really nicecgg17 is just really nice
cgg17's Avatar
1995 SL2
Default Cps
Hello all,
I am making the trek to Boston Ma for the extinct car show, and it is about 6 hours each way for me. My 1995 Sl2 has 155k on it, runs great, always fires up, but my father (former saturn tech) said it may be a smart idea to replace the crank sensor before coming up. I really do not want to spend the money right now, and have a spare from my 1994 Sl2's engine with only 53k on it. Now, do these go bad over time or from mileage? If age doesnt matter too much Ill just head up with the spare CPS in my trunk just in case, along with spare coils and module.
Thanks for the advice,
Chris
1994 Sl2 5spd: 56,576 (Totaled 1/10/2018)
1995 Sl2 5spd Manual Swap: 150,062
1999 Sl2 4spd: 98,8xx
Old 10-02-2018, 09:13 PM   #2
dummo
dummo's Avatar
1997 SW2
Default Re: Cps
Father knows best. Bring him with you! I want to say hello to the both of you.
1997 SW2 used 12/29/2011 with 124,200 -27 mpg
2004 Ion3 new 11/2003 (totaled) 11/2011 -23 mpg
1994 SL1 new traded
1992 SL2 new traded for above
Old 10-02-2018, 09:15 PM   #3
toggenburg
toggenburg's Avatar
Default Re: Cps
Does your father have a premonition of the car dying out on you?
If so, maybe you could show him some honor and just change it out for his sake. Besides, its a whole lot easier to change at home rather than somehow trying to crawl (better on a support) under at an unconvenient spot in the dark.
Old 10-02-2018, 09:20 PM   #4
cgg17
cgg17's Avatar
1995 SL2
Default Re: Cps
I guess I will order one from rockauto and make sure it gets installed before I come up.
I told my dad he should come, he thinks we are all nuts for loving our saturns. Hes not a true fan...
It is a shame because you could all pick his brain like I do.
He worked there from 1995-2000, so he was in the height of the S-Series Boom.
Old 10-02-2018, 09:38 PM   #5
nealt
nealt is on a distinguished road
nealt's Avatar
1997 SC2
1999 SC2
Default Re: Cps
I bought a CPS sensor from Advanced Auto Parts with lifetime warranty. Mine seems to die every 3-4 years. I now replace it every other year as "preventive maintenance"... even if there are no symptoms. I refuse to get stranded again from a failed CPS.
If you are a low mileage driver, then it may not fail as often. I think the heat is hard on these sensors.
nealt is offline   Reply With Quote
Old 10-02-2018, 10:40 PM   #6
cgg17
cgg17's Avatar
1995 SL2
Default Re: Cps
I am going to get the AcDelco gm oem rated one, hoping it will be a good choice.
Old 10-03-2018, 10:32 AM   #7
Default Re: Cps
I think I read (from OldNuc, maybe?) that they work fine until they fail.
They fail when hot, and letting it cool down means you can start the car again and it will run until it overheats again.
Also read that pushing the car so that one side is up on a curb gives you enough room to crawl underneath to change (fetchitfido, maybe?)
I've driven 2 Saturns daily for the past 9~10 years. Knock on wood, have yet to have one fail on me.
First Saturn, the silver one in the avatar pic, I drove for ~8 years and 100k miles (has over 200k miles on it, engine still runs great), AFAIK on the original CPS
Doesn't hurt to change it, and you can keep the old one in the glovebox for a spare
