#1 |
![]() Join Date: Dec 2012
This weekend I swapped out the front drivers seat in my XE5. Unfortunately after plugging the under seat electrical connector and bolting everything down the air bag icon in the speedometer cluster stays on. Also I do not get the seat belt icon displayed when the belt is not secured. It is there when in before start up test mode then after start up the icon disappears.
I did not get the same exact seat, I got one without the heated feature. The only difference in the wiring is that there are no connecters for the heated seat feature in the under seat plug-in. This is OK since this is only temporary until I slip on replacement OEM covers and replace the cushions in the original seat that was taken out. With the side air bags, that should be a fun job. I did not think I was that big of a lard ass that would flatten the out cushions in these cars, but (butt) apparently, I am big enough. Anyways, I probably should bet the car scanned and go from there. It seems one or more components of the system are not functioning. I read that the air bags now may not deploy in a crash with tis warning icon on. Well, I do not want to crash my Astra and I do always wear the seat belt. What to do. I think it could be a bad center seat belt mount since the seat belts unfastened warning icon does not display, Or maybe not, because in the test function it does. What to do. What are your thoughts? Thanks in advance.
PaulR 2008 XR3 5 speed, heated seats, leather, premium sound , 18" wheels, center armrest 2008 XE5 5 speed, heated seats, panoramic moonroof |
#2 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2015
2002 L-Series 3.0L Wagon
2002 L-Series 2.2L Sedan
Either the harness is different or the side airbag is bad in the replacement seat. If it worked correctly before and you are going to rebuild and reinstall the original seat, why would you pay someone to scan the problem you caused?
2002 LW 300 loaded, just rolled 100,000 miles, new timing belt and goodies 2002 L200/5 Loaded, 280k grandson’s car 2000 LS1, TMU love those bcm failures., grand daughter’s car |
Bookmarks |
Person Most Knowledgeable on Swapping Head Unit CD 30 to CD 40 | JFS | Astra Tech | 1 | 08-14-2017 01:03 AM |
I'm swapping the head unit on my car and need help, please! | SC2driver2002 | S-Series Tech | 0 | 01-16-2014 05:25 PM |
Drivers Seat Belt Light Stays On | Majorxlr8n | Aura General | 9 | 09-18-2013 11:47 AM |
Mesh Support under drivers seat... (common caved in drivers seat) | mattachuz | L-Series General | 8 | 02-12-2012 06:22 AM |
trans swapping, problem with gear selector unit swap | spyderem1 | S-Series Tech | 1 | 08-05-2007 09:32 PM |
