Old 08-23-2011, 10:39 PM   #1
M@M
M@M is on a distinguished road
Default Clutch replaced: pedal won't move
Replaced my clutch today, got it all bolted back together, and went to check and see if the clutch worked. Wouldn't move past the top position. Checked the slave and it seemed okay, and I can see the release lever in the hole when I have the slave removed. I tried manually pushing the release in with the back of a screwdriver and it wouldn't move at all. Did I screw up setting the release lever and have to remove the trans again? Trans is not filled with fluid yet but given how little movement there is (none), I don't think that is a huge factor, but would love it if it was.
Halp, I really don't want to unbolt the trans and eveyrhting associated AGAIN!!!
Cheers
Michael
Ps: Car is a 93 Sl1 with 100k kms.
93 SL1 5spd
Add to M@M's Reputation
Rate the quality of this post and help M@M reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
M@M is offline   Reply With Quote
Clutch stuck in my 99 Saturn SL2? Pedal still can move, but car won't start in 1st? SeanMaster364 S-Series Tech 19 05-04-2012 12:37 AM
1997 Saturn SC1: Clutch Pedal Won't Move Chadd.Lackey S-Series Tech 0 05-01-2011 09:50 PM
Clutch pedal will not move. cola S-Series Tech 5 10-05-2008 02:42 PM
Clutch Pedal Wired220 S-Series General 3 11-12-2004 10:55 AM
Clutch fluid level, clutch pedal vibration, small leak Heartbeat - '95 SL2 Miscellaneous Tech 10 10-10-2003 06:35 PM
