Old 10-26-2020, 10:19 AM   #1
Ccrussell
Ccrussell has a spectacular aura aboutCcrussell has a spectacular aura aboutCcrussell has a spectacular aura about
1999 SL1
1999 SC2
Default Sl1 rebuild
Hello,
I decided to rebuild my single cam engine. Had machinist hone block, polish the crank, valve job on the head.also decked the head.i will reassemble as he wanted additional 500 for installing pistons and crank.
He provided the master kit for the rebuild. Thought the overall cost to be a little high,but I may be out of touch with costs these days( and I waited nearly 8 weeks to get it back.)
While pistons are out, I will do the oil control modification. But I digress ,
My question is this, is there a gasket or Oring for the oil pump pickup tube? While I disassembled it I did not see one. Thanks
Ccrussell is offline   Reply With Quote
Old 11-07-2020, 01:39 AM   #2
TomM96
Default Re: Sl1 rebuild
about the pickup: I don't remember !
-the OEM FSM may mention-
I found a few old threads concerning the cracked heads on SOHC engines.
Several of the posters are qualified Saturn techs with lots of experience.
It turns out that Saturn had determined that there were casting/metallurgical issues in the head which were also at fault.
Then, as OldNuc discovered, there was the head-torqueing issue as well.
threads:
SOHC engine Head Cracks
http://www.saturnfans.com/forums/showthread.php?t=16384
http://www.saturnfans.com/forums/showthread.php?t=21019
http://www.saturnfans.com/forums/showthread.php?t=23424
Old 11-09-2020, 11:02 AM   #3
Highmile
Highmile's Avatar
Should be an oring on the pickup tube. Should also be in the gasket set.
Heads can and do crack however I suspect most of the bad heads have long since failed. Keep your temp in check and you'll be fine. I never let my temp get above 5/8 on my gauge before I cycle the a/c to make the fan run. The miles I have speak for themselves.
Highmile
'95 SL1 718k and counting
99 sw2 rebuild THEEwhiteboy S-Series Tech 3 04-27-2015 08:25 AM
AC rebuild kit? 92SC2 S-Series Tech 11 07-09-2010 10:37 PM
VTi M75 Rebuild Kit? pontgtp2001 Ion General 1 04-14-2009 03:04 PM
Seeking advice on engine rebuild (Subaru.. and rebuild done) Scyan Miscellaneous Tech 8 06-13-2003 09:38 AM
Rebuild $? ProDarwin Mods and Performance 6 02-05-2003 11:10 PM
