Old 03-12-2008, 08:22 AM   #1
banditkaine
banditkaine is on a distinguished road
banditkaine's Avatar
Default 2002 SL2 High Idle
i have a 2002 SL2 and it strated idling at 2000 rpm, in neutral and park, when i put it in drive (auto trans) it rolls on its own rather fast. sometimes it won't idle high. turned it off and back on and it went back to normal, but when i drive for a bit it idles high again. also the airbag light flashed when i was at a stoplight. any ideas what this can be?
Add to banditkaine's Reputation
Rate the quality of this post and help banditkaine reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
banditkaine is offline   Reply With Quote
Old 03-12-2008, 10:58 AM   #2
rc1488
rc1488's Avatar
Default Re: 2002 SL2 High Idle
Clean your throttle body first off. Make sure all the passages are clean especially the IAC.
The airbag light makes me ponder tho. Search for information about it and see what turns up.
Add to rc1488's Reputation
Old 03-12-2008, 01:06 PM   #3
fredsfix
fredsfix is on a distinguished road
fredsfix's Avatar
1999 SL1
1997 SL1
Been into any of the quick lube places lately? Check any vacuum lines to be sure they're connected right, especially the one in the throttle body right beyond the oil fill cap. Worked for me.
As for the air bag light - lean waaaay back and reach for the steering wheel
You can't call yourself a mechanic if you're surprised it runs!
Add to fredsfix's Reputation
Rate the quality of this post and help fredsfix reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
fredsfix is offline   Reply With Quote
Old 03-13-2008, 06:59 AM   #4
banditkaine
i disconnected the battery for a few hours and now everything works fine o.O beats me what the deal was.. maybe the PCM got confused? but the RPMs so far seem to be normal and the airbag light has not come on again.
Old 03-13-2008, 07:15 AM   #5
Phredawgy
Phredawgy's Avatar
How long were you having these symptoms?
Add to Phredawgy's Reputation
Old 03-13-2008, 08:25 AM   #6
banditkaine
it only just started yesterday.. drove it a few miles today after disconnecting the battery and everything seems ok. it was raining hard when it started.. could that have something to do with it?
Old 03-13-2008, 08:33 AM   #7
Phredawgy
Phredawgy's Avatar
hopefully then it was just a fluke
Old 03-13-2008, 09:13 AM   #8
wislauson
wislauson is on a distinguished road
Had the same exact problem with my SC1. This is most likely the ECTS...what can happen is it can get stuck on a certain reading (high or low) and then continue to send the wrong information about what mixture to use. If it thinks the engine is cold, it will continue to call for a high idle. Shutting the car off and then starting it again basically lets it "reboot." The problem will come and go, but it will get progressively more frequent. If you let this go you'll get to a point where shutting the car off doesn't work any more. The good news is it's an easy fix...the technician will take a reading of the coolant temp and then compare that to what the ECTS is sensing and there will probably be a discrepancy. The IAC and throttle body being dirty can also cause this, and you should have those cleaned also, but your car is doing exactly what mine did and my money is on the ECTS.
A lot of people have experienced this. It's nothing exotic for the S-Series, just one of it's idiosyncracies.
Add to wislauson's Reputation
Rate the quality of this post and help wislauson reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
wislauson is offline   Reply With Quote
Old 03-13-2008, 09:17 AM   #9
Phredawgy
Phredawgy's Avatar
What year is your SC1. I'm not real familiar with alot of people with 2002 models having trouble with their ects
I wonder if the op problem could have been, or might be a goofy tps
Old 03-13-2008, 12:30 PM   #10
rc1488
rc1488's Avatar
Its NOT the ECTS.
2002 S-series have Brass sensors from the factory.
Old 03-13-2008, 02:53 PM   #11
banditkaine
ok so drove it some more to work and back. like 20 miles. didn't do it this time. at one point i thought it was a bit revved up but didn't get a chance to put it in neutral to find out what the rpm's were then.
Old 03-13-2008, 03:35 PM   #12
wislauson
It's always frustrating when problems are intermittent. Inevitably when you take it in it's not doing it and you get the "can't duplicate problem" response.
My SC1 is a 2001...I didn't know that the 02's had the brass sensors which apparently never go bad. If that's not the problem then I would guess the problem lies with a dirty throttle body, dirty/bad IAC, or a bad TPS sensor. My problem did go away once the ECTS was replaced but came back three months later with a vengenace. This time in addition to the high idle, the engine would choke itself off whenever I'd come to a stop. It's no fun driving an automatic with one foot on the brake and one on the gas...I had to shift it into neutral and manually keep the RPMs up to keep the car running.
Does it ever "feel" weird? I remember the on the day I had the TPS replaced and throttle body cleaned, it just didn't feel like it was running right at freeway speeds. I'd let my foot off the gas and instead of the car just sort of coasting it would bog down--again sort of like it was being choked off. My car's been running like a top since then, although it's now a two door coupe since I got in an accident and the passenger side door handle is pushed in and jammed. I still have the regular door and suicide door on the driver's side and since I'm the only one in my car it doesn't bother me all that much.
I'd get it looked at. Unfortunately this isn't going to go away and you don't want to wait too long and risk getting stranded and having to pay for a tow.
Old 03-13-2008, 06:25 PM   #13
rc1488
rc1488's Avatar
My SC1 is a 2001...This time in addition to the high idle,
Your car is a different situation. Id recommend you spray some brake cleaner near your intake manifold gasket during idle and listen for changes. If you hear a difference you just found your problem. Your intake manifold gasket is wrinkled.
High Idle Speed 2002 SL1 journeyman615 S-Series Tech 9 10-20-2014 03:20 PM
2002 l200 high idle revs tom_foolery L-Series Tech 2 06-13-2009 11:10 PM
HELP!! SL2 High Idle Fireball69 S-Series General 3 11-23-2006 11:51 AM
2002 SL 1.9L SOHC - High Idle Killjoy S-Series General 9 04-17-2006 08:35 PM
2002 AWD V6 high rev at idle Uzzi Vue Tech 13 03-28-2006 08:08 PM
