Old 11-22-2015, 09:30 PM   #1
DawnR
DawnR is just really niceDawnR is just really niceDawnR is just really niceDawnR is just really nice
DawnR's Avatar
1997 SW2
Default A/C. Defrost and Recirculate buttons ?
Does anyone know off hand of those buttons are spring loaded. Push it in and the indicator light comes on. Push out again the button pops back out and the light goes off. I have one that will not turn off after pressing to turn it off. No action on the button.
I did install an aftermarket radio. My search results are only listing people who have a radio harness wire stopping the large circular dials that control heat setting, fan speed, and the heat location (defrost, feet, etc)
I found this image that shows the backside of the climate control unit. I don't see much in terms of the middle section. If anyone is familiar with this please share. I will fix this if it can be fixed. If it is a spring loaded button and if there is anyway to access it.
I read, I learn, I try!
Add to DawnR's Reputation
Rate the quality of this post and help DawnR reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DawnR is offline   Reply With Quote
Old 11-23-2015, 02:53 PM   #2
Default Re: A/C. Defrost and Recirculate buttons ?
Is this for you '97 SW2, or for the '01 SC2?
For the '97, there's a richpin video showing how to replace the bulb (I think), that will show how to remove the panel and remove the buttons. No clue on the SC2, though
Old 11-24-2015, 02:34 PM   #3
toggenburg
toggenburg's Avatar
Sounds like the switch is bad, not the bulb.
Old 11-24-2015, 03:13 PM   #4
SC2Sick
1995 SW2
That's not the back of the unit you're talking about.. well at least not for a 97.. the 97 is spring loaded.. I know this because I lost one of the springs on disassembly and had to get a whole new unit for my plan
sixthsphere.com owner
2002 Saturn SL2 - RHD
Add to SC2Sick's Reputation
recirculate problems mjoekingz28 S-Series Tech 3 04-13-2011 09:56 AM
A/C and recirculate air mode dddkim Aura General 4 01-23-2010 11:18 AM
Why can't I recirculate without A/C brubins Aura General 16 04-29-2009 08:32 PM
Dead buttons (defrost/windows) 92SC2 S-Series Tech 18 04-09-2008 05:37 AM
02 SC2 Air, Rear Defrost, Ventilation Buttons Sticky/Stuck E Keith Johnson S-Series General 1 11-08-2007 12:52 PM
