Old 05-04-2019, 03:10 PM   #1
jlbmusic
jlbmusic is on a distinguished road
Default ABS Sensor Bolt
The ABS sensor bolt snapped when I was trying to remove it. Does anyone know the specs for that bolt. I need to replace it.
jlbmusic is offline   Reply With Quote
Old 05-08-2019, 07:36 PM   #2
TomM96
Default Re: ABS Sensor Bolt
I guess, try a junkyard.
It helps to:
1- use penetrating lube some hours/days beforehand
2- tap the head of the fastener (directly along the shaft, to jostle the bolt down along the threads) with something, like pliers, wrench, hammer.
As vehicles age, stuck fasteners become a big issue, particularly in wet/salty
areas.
Tags
abs, antilock, bolt, brakes, sensor
'01 SW2 engine coolant drain plug bolt issues and ISO new bolt hangten247 S-Series Tech 7 06-23-2016 10:28 PM
what are the timing belt tensioner bolt and idler pulley bolt torque values goob Astra Tech 4 10-14-2015 08:05 PM
Crank Position Sensor Bolt/Removal td1238 S-Series Tech 1 02-04-2014 07:32 PM
its a long shot but bolt size for front abs sensor bttwracing S-Series Tech 0 01-20-2010 10:30 PM
Bolt Fairy Strikes! Timing cover middle bolt size? alordofchaos S-Series Tech 8 08-04-2009 11:58 PM
