#1 | ||||
![]() Join Date: May 2014
![]() I have no power at the backup lamps.
I have power at the fuse. Key on I have power power at the backup switch connector pink wire. Key on shifter in reverse I have power on the light-green wire at the backup switch connector so switch is ok. Key on shifter in reverse I have no power at the light-green wire in the rearview mirror so presumably the problem is in the front somewhere? Before I start unraveling wiring I was hoping someone had some idea where a likely light-green wire break would be in the engine compartment. Is there a connector somewhere? Thanks.
#2 | |||||
The BU voltage is split inside UHFB and normally goes to mirror (C3-A1) and two L-GN wires will be connected to C3-A5 going the rear lamps. Wires entering bottom of UHFB have been known to break due to sharp bends so you might try wigging harnesses to confirm open circuit is outside UHFB. ... I don't spend much time on forum but answer private messages (PM email my phone). Include email address if you need pdf extracts. Don't use visitor message - I forget to check those.
#3 | ||||
![]() I pierced the light-green wire found in a small bundle maybe 5-6 inches from the back of the box and found batt voltage ok.
As you say break is likely where the wires come together and enter the box. Tried wiggling... no joy. Thanks for the box diagram. Too cold now to attempt taking that box apart. May have to wait until spring.
#4 | |||||
Is it possible the small harness you located has other light green wires? If yes I'd be tempted to "test-connect" supply wire to another light green wire ... if successful ... tie all together and bypass the UHFB. ![]() ... I don't spend much time on forum but answer private messages (PM email my phone). Include email address if you need pdf extracts. Don't use visitor message - I forget to check those.
#5 | ||||
![]() I’m sure I had the right conduit. I followed it up from the backup switch connector and the other (speed sensor?) connector on top of the transmission.
Its a maybe 10mm plastic tube with only 5-6 wires.
#6 | ||||
![]() You can also Run a jumper wire To the mirror circuit 24, if the reverse lights come on everything in back is good
Installing a backup camera, and I need help locating the "Reverse Lamp Harness" | Aloupha | Ion General | 4 | 08-28-2016 06:19 PM |
2005 Vue V6 AWD Backup Lights Not Working | OhFive Vue | Vue Tech | 3 | 07-26-2016 09:52 AM |
Dead short in tail lamp circuit | Ashkicker | S-Series Tech | 5 | 05-29-2015 06:00 PM |
3057 bulb used as a backup lamp? | Bismarck318 | Vue Tech | 15 | 05-31-2011 10:41 PM |
2004 ION MU3 Manual Backup Lamp Switch - NEED HELP! | javajeff | Ion Tech | 11 | 12-31-2008 10:27 AM |
