Old 02-08-2019, 10:27 AM   #1
Steve_Vue
Steve_Vue is on a distinguished road
Default 2007 Saturn Ion Possible motor swap
I have a 2007 Saturn Ion and the 2.2liter motor is shot. I am looking for a motor and having trouble finding the right fit. I have located a 2009 Chevy Cobalt motor. Anyone know if this motor will fit? I do believe it is a 2.2liter as well. Any help is always most appreciated!!
Steve D.
Add to Steve_Vue's Reputation
Rate the quality of this post and help Steve_Vue reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Steve_Vue is offline   Reply With Quote
Old 02-09-2019, 12:32 AM   #2
19boneatock88
19boneatock88 is on a distinguished road
2004 ION-2 Sedan
2006 ION-2 Quad Coupe
Default Re: 2007 Saturn Ion Possible motor swap
Iím not 100% sure whether it will or not. I think GM revised the engine again in either 2009 or 2010 to include VVT, that engine is RPO code LAP... now, one could speculate that running it without connecting anything to the cam phasers would solve the issue, but Iím not totally sure... then again if the engine is listed as RPO L61 then itíll work just fine...
EDIT: after some further research it appears that a 2009 engine is the LAP, and you need an L61, which was offered in the exact configuration you need only in 2007 and 2008... now, one could speculate that you could sit an 07 head on that 09 block and have a compatible engine but itís a lot of work for a ďmaybeĒ
Jerama- WV
2004 Saturn Ion-2 sedan
L61/F23(M86), 139k...
Too many mods to list in sig...
ďStockĒ is nowhere in my vocabulary...
Add to 19boneatock88's Reputation
Rate the quality of this post and help 19boneatock88 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
19boneatock88 is offline   Reply With Quote
Old 02-11-2019, 11:34 AM   #3
Steve_Vue
I was wondering if I just use the head and mate it to the '09 block. Not sure. I asked the guy selling the motor to give me some good pictures of it. Problem is I am not seeing the entire thing. I did take the head off of the '07 engine and had everything gone through. Maybe I could buy the motor and put the '07 head on it. Replace the water pump and timing chains.
I hope this works out!
Old 02-11-2019, 11:34 PM   #4
bern
bern is just really nicebern is just really nicebern is just really nicebern is just really nicebern is just really nice
2004 ION-2 Sedan
A 2.4 liter has variable Cam timing and higher compression ratio then the 2.2 liter. Also the 2.4 liter had a longer stroke And In larger boar Requiring more fuel. A 2.2 liter head on a 2.4 liter 4 probably run lean, running engine with excessive pinging without being able to retard Cam timing.
Add to bern's Reputation
Rate the quality of this post and help bern reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 03-11-2019, 09:35 AM   #5
Feak1
Feak1 is on a distinguished road
thank for the useful info!
Add to Feak1's Reputation
Rate the quality of this post and help Feak1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Feak1 is offline   Reply With Quote
2007 Saturn Ion Motor Swap Steve_Vue Ion Mods 2 02-07-2019 02:40 PM
2007 Motor Question DotleChris Vue General 2 10-09-2015 12:28 AM
Motor swap/Motor Build ideas 95-SC2 S-Series General 5 02-26-2013 12:20 AM
saturn sc2 motor swap possibilities... cpriv91 S-Series General 1 02-03-2010 02:20 PM
A motor swap questing for all you Saturn tech. JUSS600RR S-Series Tech 19 04-12-2008 12:46 AM
