Go Back   SaturnFans.com Forums > Models > Saturn Ion > Ion Mods
Old 02-01-2019, 06:18 PM   #1
Steve_Vue
Steve_Vue is on a distinguished road
Default 2007 Saturn Ion Motor Swap
I have a Saturn Ion sedan with a 2.2liter motor that went bad. I manged to take the head off and have it "gone through". To make sure there wasn't any issues with it. The bottom end of the motor was bad. Two out of the four pistons were stuck in the block leaving me to get rid of that. I have a motor from an '03 Saturn Vue that I am planning on using, but I do see that the crankshaft sensor can be an issue with an older block. From what I have heard the newer blocks 2007 and up have something in the crank that the sensor uses as a "pick-up". I guess what I am wondering, is that true, and second is there something I can use that is after market that I can install that looks at the harmonic balancer? Any news or help is most appreciated!
Thanks,
Steve D.
2002 Saturn L200
2003 Saturn Vue
2006 Saturn Ion 3
2007 Saturn Ion 3
2017 Chevy Malibu
1997 Chevy Suburban
1968 Chevy Chevelle
Add to Steve_Vue's Reputation
Rate the quality of this post and help Steve_Vue reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Steve_Vue is offline   Reply With Quote
Old 02-02-2019, 12:37 AM   #2
19boneatock88
19boneatock88 is on a distinguished road
2004 ION-2 Sedan
2006 ION-2 Quad Coupe
Default Re: 2007 Saturn Ion Motor Swap
I donít think that there is anything that would read off the harmonic balancer and talk to the factory PCM... there are external crank trigger kits but they usually require a standalone engine management to run them... Iím guessing that finding an 07 2.2 is hard/expensive?
Jerama- WV
2004 Saturn Ion-2 sedan
L61/F23(M86), 139k...
Too many mods to list in sig...
ďStockĒ is nowhere in my vocabulary...
Add to 19boneatock88's Reputation
Rate the quality of this post and help 19boneatock88 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
19boneatock88 is offline   Reply With Quote
Old 02-07-2019, 02:40 PM   #3
Steve_Vue
Ok. I found a different motor for my project 2007 Ion. Will a 2009 Chevy Cobalt 2.2 motor work ok in my Saturn Ion 3? I don't want to change anything in the motor except the timing chain and water pump.
Any help is always appreciated!
Steve D
2007 Motor Question DotleChris Vue General 2 10-09-2015 12:28 AM
Motor swap/Motor Build ideas 95-SC2 S-Series General 5 02-26-2013 12:20 AM
2007 ION Blower motor unique? Diesel_Clatter Ion Tech 0 11-11-2010 12:25 PM
saturn sc2 motor swap possibilities... cpriv91 S-Series General 1 02-03-2010 02:20 PM
A motor swap questing for all you Saturn tech. JUSS600RR S-Series Tech 19 04-12-2008 12:46 AM
