Old 11-20-2011, 12:51 PM   #1
mmmantei
mmmantei is on a distinguished road
Default Relay oil leaking
Amongst all the fun I am having with my relay, I just noticed that oil is starting to leak from around the oil filter housing, a lot! I heated up the engine and can see the oil is coming from the seam on the housing, not where the filter comes in contact but just beyond. Also, there is a bunch coming from one of the bolts where the housing connects to the block. Is this as easy as changing the gaskets or oil filter housing?
Add to mmmantei's Reputation
Rate the quality of this post and help mmmantei reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mmmantei is offline   Reply With Quote
Old 07-08-2017, 01:23 PM   #2
henryr79
henryr79 is on a distinguished road
2007 RELAY-3
Default Re: Relay oil leaking
Yes, it is an easy fix. There is a gasket between the block and the oil filter adapter. If I remember correctly, since I changed mine, there are three bolts that hold the adapter to the block. The gasket is available at O'reilly Auto.
Add to henryr79's Reputation
Rate the quality of this post and help henryr79 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
henryr79 is offline   Reply With Quote
What's different about the ABS relay? PlasticCarsRock S-Series Tech 2 08-24-2010 02:40 PM
Front discs leaking, rear drums leaking. Derekleu S-Series Tech 11 07-10-2007 11:14 AM
We have a Relay saturnguy0077 Relay General 22 11-08-2004 09:20 PM
Relay... Yokozuna Relay General 16 12-03-2003 05:20 PM
