Old 07-23-2017, 06:17 PM   #1
dasdream
dasdream is on a distinguished road
Default Wiring Diagram or wiring advice
I found out that the main ground wire that grounds the MAF has been shorted somewhere and I haven't been able to locate the spot. Does anyone have the reference for an 08 Astra wiring diagram? I can't seem to find one. Also, if I cut the ground wire for the MAF and reground it somewhere else, would that work? I believe it is the blue and purple wire supplying ground. I have continuity but no ground.
Add to dasdream's Reputation
Rate the quality of this post and help dasdream reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dasdream is offline   Reply With Quote
Old 07-23-2017, 08:43 PM   #2
SRGW
SRGW is a glorious beacon of lightSRGW is a glorious beacon of lightSRGW is a glorious beacon of lightSRGW is a glorious beacon of lightSRGW is a glorious beacon of lightSRGW is a glorious beacon of light
1997 SL1
Post Re: Wiring Diagram or wiring advice
Is this of any help??
1995 SL1 229,922 Well Oiled!!
1997 SL1 61,800 Just A Teenager!!
CHECK YOUR OIL!!
Add to SRGW's Reputation
Rate the quality of this post and help SRGW reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 07-25-2017, 01:53 AM   #3
dasdream
Default Re: Wiring Diagram or wiring advice
If that is the wiring diagram for the Saturn Astra then yes that will help me
Old 07-25-2017, 10:13 PM   #4
emg77
emg77 has a spectacular aura aboutemg77 has a spectacular aura aboutemg77 has a spectacular aura about
emg77's Avatar
2008 Astra XR
Ground is ground, so yes, you should be able to re-ground it someplace else in the system without issue.
Drives: 2014 Volt, 2017 Acadia
Past Cars: 08 Astra, 15 Acadia, 12 Enclave, 09 Traverse, 05 Vue, 04 Grand Prix, 00 Alero, 97 LeSabre, 72 Cutlass S
Add to emg77's Reputation
Rate the quality of this post and help emg77 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
emg77 is offline   Reply With Quote
Looking for wiring diagram please Hfxfieroboy Vue Tech 2 08-21-2014 08:48 PM
need wiring diagram sattyluvr S-Series Tech 1 02-18-2011 08:21 PM
I need a wiring diagram maxbobb0002 Aura General 13 06-21-2007 01:18 PM
i need help, i need a diagram or map of the ac wiring gypsy35 L-Series Tech 0 08-22-2006 05:04 PM
2001 SC2 wiring diagram? (trailer wiring harness) gumpish S-Series General 1 05-01-2005 12:45 AM
