Old 06-29-2007, 02:44 PM   #1
remedys
remedys is on a distinguished road
remedys's Avatar
2001 SC1
Default Cruise Control after a swap
I was wondering if there was any way possible to fix my cruise control. I swapped in a 2002 DOHC in to 2001 sc1 last year. I still have the 2001 5spd, and I am using a 2002 DOHC PCM and BCM from another car. Is there any way possible to get the factory CC working again? I was thinking of wiring an aftermarket one to the factory controls.
SC1, DOHC swap, Nitrous wet kit, expressions lip kit, 2" drop, 17" konigs, full exhaust.
Add to remedys's Reputation
Rate the quality of this post and help remedys reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
remedys is offline   Reply With Quote
Old 06-29-2007, 02:53 PM   #2
skewbe
skewbe is on a distinguished road
Default Re: Cruise Control after a swap
I'm working on it myself. The ratios are hard coded in the pcm. So far all I can think of is a circuit in line with the vehicle speed sensor that sends out a pulse that makes it looks like it has the 5th gear ratio the pcm is expecting...
Of course your speedo and odo will be (more) off as a result.
Note: I talked to the service guys at the dealer and didn't get anywhere.
Add to skewbe's Reputation
Rate the quality of this post and help skewbe reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
skewbe is offline   Reply With Quote
Old 06-29-2007, 03:56 PM   #3
BarnOwl
BarnOwl's Avatar
That's an ambitious project skewbe. remedys short of doing something like skewbe has in mind or going with an aftermarket CC, you'd need to swap a transmission from a DOHC in there to get it to work. The PCM uses the gear ratios to determine that you've pushed in the clutch. If they're way off already, it's not going to let the cruise control work.
Add to BarnOwl's Reputation
Old 06-29-2007, 07:09 PM   #4
geartooth94
geartooth94's Avatar
the cruise control works excellently in my manual trans-swapped 1991 SL2.
although in the early years, the cruise module was separate from the PCM and there was no BCM involved. i also do not use a clutch start switch, so i don't know if my cruise would turn off if the clutch pedal is in: kinda scary ...
Add to geartooth94's Reputation
Rate the quality of this post and help geartooth94 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
geartooth94 is offline   Reply With Quote
Old 06-29-2007, 08:27 PM   #5
eljefino
eljefino's Avatar
1995 SW1
Audiovox makes an aftermarket cruise control one can buy through JC whitney.
Pay the extra ten bucks and get the "electric" one that doesn't need vacuum.
Hooking this up to your stock switch will be next to impossible as the stock switch uses "resistive multiplexing". But the kit will include a switch.
Add to eljefino's Reputation
Old 06-30-2007, 01:06 AM   #6
Part of the problem may be that the DOHC PCM may not have been programmed with cruise.
I think though that the main problem is that you have a DOHC PCM with a SOHC trans. The PCM expects a certain RPM at a certain road speed. If it does not see that then the cruise will not work.
Add to ssicarman's Reputation
cruise control swap 95 to 96 bigbfarm S-Series Tech 7 07-24-2009 06:08 PM
Cruise control swap, 95 to 96 95satnut S-Series Tech 21 02-01-2009 02:53 PM
Cruise control swap snydley S-Series Tech 9 04-05-2008 10:46 AM
99 sw2 auto cruise control swap to 95 sc/2 5 spd. Alutious S-Series Tech 11 02-15-2008 03:14 PM
Cruise Control Swap for 97 SL2? SilverBullit S-Series General 3 08-04-2003 04:36 PM
