Old 06-03-2012, 07:40 PM   #21
Default Re: Rebuilt Transmission, Now Fails Smog Check
Clean the front and rear O2 sensor grounds located above the starter on the back of the block,10mm wrench to undo the bolt. You can reach them from the top left side if you remove the air intake.
Do you know if they removed the engine to change out the transmission?
Front O2 sensor bench test. http://www.youtube.com/watch?v=vdn4Dk5PSwc Color means next to nothing....
Old 06-03-2012, 11:15 PM   #22
RCH
RCH is on a distinguished road
I don't know if the engine was remove for the rebuild.
I will test the front sensor, I replaced the rear one.
Would replacing plugs and plug wires help?
Richard
RCH is offline   Reply With Quote
Old 06-03-2012, 11:24 PM   #23
If they are well worn or platinum then replacement should help. New plugs (NGK) and wires are standard pre-smog test maintenance along wit oil and filter. The grounds on the back of the block will cause you to run excess HC on a smog check if dirty.
Old 06-04-2012, 11:31 AM   #24
RCH
Will do , she is comming over tomorrow so I can work on it.
I will report back when I find out how it goes.
Thanks.
What is Saturn's equivalent of "Check engine light"? Smog won't pass bulb check. harmono S-Series General 5 02-28-2012 11:17 AM
94 SL2 fails smog douglasfry S-Series General 2 01-31-2012 07:25 PM
History repeats itself... 2 years later and car again fails smog strongboy2005 S-Series Tech 22 11-12-2010 10:57 PM
93 sl fails smog SES & high NO zigstarre S-Series Tech 3 11-12-2008 08:30 PM
Single Mom FAILS Smog Check HELP! OhBlahDah S-Series Tech 11 07-17-2006 01:11 PM
