Old 05-05-2007, 11:33 PM   #1
beensmoked
beensmoked will become famous soon enough
2001 L-Series 3.0L Sedan
2002 L-Series 2.2L Sedan
Default Starter Broke
My Starter isn't working properly and needs to be replaced. Fortunately it happened infront of my aunts house. My question for u guys is what EXACT Tools and SIZES I need to change it out.
Add to beensmoked's Reputation
Rate the quality of this post and help beensmoked reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
beensmoked is offline   Reply With Quote
Old 05-06-2007, 10:34 AM   #2
beensmoked
Default Re: Starter Broke
Well I found out that the whole starter housing was cracked and loose and was manage to get it started with a piece of wood. Now my question is has anynoe changed there starter? Looks like a hard job...I basically have to take off the REAR MANIFOLD off to get to it easily. Has anyone changed there Starter in the 3.0??
Old 05-06-2007, 12:28 PM   #3
I have yet to do one on the 3.0 LT engine. THis is from the service manual.
Starter Motor Replacement (L81)
Removal Procedure
Turn the ignition OFF.
Disconnect the negative battery cable.
Jack or raise the vehicle on a hoist.
Remove the right front wheel.
Disconnect the 2 starter solenoid electrical connections.
Important: Loosening the fastener will allow the harness bracket to move enough to clear the starter using the J44830 or equivalent (#16 TORX) wrench.
Loosen the fastener securing the electrical harness bracket to block.
Remove the lower starter assembly to engine block bolt.
Lower the vehicle.
Remove the upper starter assembly to engine block bolt.
Move the starter right, clearing the engine block, then left and out of the engine block (flywheel housing).
Installation Procedure
Guide the starter into the engine block (flywheel housing).
Install the upper starter mounting bolt finger tight.
Raise the vehicle on a hoist.
Install the lower starter mounting bolts.
Tighten
Tighten the lower starter mounting bolts to 40 Nm (30 lb ft).
Install the B+ cable and nut.
Tighten
Tighten the B+ cable to starter nut to 9 Nm (80 lb in).
Install the S-terminal wire and nut.
Tighten
Tighten the S-terminal nut to 4.5 Nm (40 lb in).
Connect the negative battery cable to the battery.
Tighten
Tighten the battery terminal bolts to 17 Nm (13 lb ft).
Install the right front wheel.
Position the wheel onto the hub.
Install the wheel bolts and tighten in a star pattern.
Hand tighten all 5 wheel bolts.
Use a torque wrench to tighten the wheel bolts using a star pattern.
Tighten
Tighten the wheel bolts initially to 63 Nm (46 lb ft).
Use a torque wrench to final tighten the wheel bolts using a star pattern.
Tighten
Tighten the wheel bolts finally to 125 Nm (92 lb ft).
Lower the vehicle from the hoist.
Tighten the upper starter mounting bolt.
Tighten
Tighten the upper starter mounting bolts to 40 Nm (30 lb ft).
Add to ssicarman's Reputation
Old 05-06-2007, 12:50 PM   #4
beensmoked
THX A LOT I would have never thought about goin through the right wheel. I was going to take off the intake manifold and do a spark plug change while i was doin it. But this is def a lot easier. Thx for the help!
Old 05-07-2007, 12:48 PM   #5
beensmoked
quick question. My starter housing is cracked so i can't even get core credit. The L Series V6. Used the same starter from 00-05 right?
Old 05-07-2007, 10:42 PM   #6
According to saturnparts.net yes.
Old 05-14-2007, 04:18 PM   #7
beensmoked
thx for the instructions. It helped out a lot! I took out the starter and it was fine just that the housing was cracked in half? How is that possible? But anywayz I found a brand new one off ebay for 50 bux so that's a plus. Thx for your help
98 SL1 broke down lordshaq S-Series General 8 12-26-2006 12:54 PM
Broke EGR? andyr13 S-Series Tech 6 07-15-2005 11:29 PM
broke 2 new headbolts.. mars_volta S-Series Tech 7 07-06-2005 08:29 PM
crankshaft broke rocknrt Miscellaneous Tech 3 07-20-2002 01:48 AM
Why I am broke OPEC General Saturn Discussion 9 02-03-2001 06:43 AM
