Old 01-14-2007, 06:06 AM   #1
Red Sc2
Red Sc2 is on a distinguished road
Red Sc2's Avatar
Default Revolutions Per Minute
Hey. It might be a dumb question but, How high does your car rev at 70? I have a 95 SC2 and it is a five-speed. At 70mph it registers 3000 rpm. The only prob with that is, my girl's sunfire is only 2200 at that speed and its a 4spd auto!! My mom's 4-spd auto elantra-2500 at that speed. Is 3000 revs normal at 70mph for a 95 sc2 with a five speed?
Add to Red Sc2's Reputation
Rate the quality of this post and help Red Sc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Red Sc2 is offline   Reply With Quote
Old 01-14-2007, 11:20 AM   #2
SaturnTech
SaturnTech is on a distinguished road
SaturnTech's Avatar
Default Re: Revolutions Per Minute
You can't compare different cars with different engines and transmission and gear ratios. Of course they won't be the same.
Add to SaturnTech's Reputation
Rate the quality of this post and help SaturnTech reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SaturnTech is offline   Reply With Quote
Old 01-14-2007, 12:26 PM   #3
eRic 02sc2
eRic 02sc2's Avatar
3000 RPM at 70 MPH is normal for a 5-speed manual SC2. don't bother comparing other vehicles since they have different gear ratios and tire sizes. some engines are lazier than others look at a V8 6-speed manual Camaro or Firebird sometime.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 01-14-2007, 10:10 PM   #4
Red Sc2
Red Sc2's Avatar
Ok so... Here's my next question. If my sat now has the standard 15 inchers, but I put 16s or 17s on there, will the revs at that speed get higher or lower with the sizes? (sorry if its a stupid question)
Old 01-14-2007, 10:42 PM   #5
eRic 02sc2
eRic 02sc2's Avatar
not much if you get the correct plus size tires.
the closest in outside diameter to 195/60-15 is 205/50-16 or 205/45-17
eRic 02sc2
Old 01-15-2007, 07:39 AM   #6
BarnOwl
BarnOwl's Avatar
Technically, if you put tires on there that actually have a larger diameter, the RPMs will go down when you are actually going 70. However, they'll be the same when your speedometer reads 70 because your speedometer will be off. You shouldn't do that. Different engines are more or less efficient at different RPMs. That's why it's not reasonable to make the comparison you are making.
Add to BarnOwl's Reputation
Old 01-15-2007, 05:48 PM   #7
MiSaturn
MiSaturn is on a distinguished road
2002 SL
1993 SL2
'02 SL, stock rims/tires - 2550rpm @ 70mph.
Add to MiSaturn's Reputation
Rate the quality of this post and help MiSaturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
MiSaturn is offline   Reply With Quote
Old 01-15-2007, 07:45 PM   #8
amazinghl
SOHC have taller gear ratio than DOHC.
00 Insight 72mpg
Add to amazinghl's Reputation
Old 01-15-2007, 08:50 PM   #9
Sky King
Sky King's Avatar
Saturntech and others are right about comparing other cars with yours. Barnowl is right about what the result will be about changing the OUTSIDE diameter of the tire. Your car will roll further with each revolution of the wheel at the same RPM. But again he is right about the RPM will be the same at the INDICATED 70 MPH because the vehicle speed is not based on wheel speed.
Two words of caution about going this route. 1, your speedometer will be in error as Barnowl said. When it says you are doing 70, you will in fact be going faster, just remember that when the speed radar is pointed at you. 2, be careful about tire rub in the wheel wells.
Add to Sky King's Reputation
Rate the quality of this post and help Sky King reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 01-15-2007, 08:52 PM   #10
Red Sc2
Red Sc2's Avatar
Thanks. Maybe I'll just get 15x7 inch rims to match the size of the already wheels!
Old 01-16-2007, 12:11 AM   #11
Rayman86
Rayman86 is on a distinguished road
1999 SL1
Im not sure if you can do this on a Saturn, but ive heard on some cars you can adjust a certain setting in the transmission that will make the spedometer read accurate with larger tires.
Add to Rayman86's Reputation
Rate the quality of this post and help Rayman86 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Rayman86 is offline   Reply With Quote
Old 01-16-2007, 06:57 AM   #12
BarnOwl
BarnOwl's Avatar
I've heard that the PCM can be reprogrammed to go from 14 to 15 inch wheels but, not for anything else and I could be mistaken about that.
Old 01-16-2007, 09:25 AM   #13
Red Sc2
Red Sc2's Avatar
My wheels are a standard 15 inch. already
Old 01-16-2007, 09:54 AM   #14
Tom92SCm
Tom92SCm's Avatar
2004 VUE 2.2L
Swap in a SOHC 5th gear into your DOHC transmission.
Not a Saturn.
Add to Tom92SCm's Reputation
Old 01-16-2007, 10:11 AM   #15
amazinghl
Your gasmilage is suffer if you do that.
00 Insight 72mpg
Last minute Purchase! ClapDaddy General Saturn Discussion 18 01-08-2006 03:35 PM
Last minute tips..... KBS_Caveman S-Series General 1 09-13-2005 08:37 AM
Last minute P/S Question FrozenPilot Miscellaneous Tech 3 02-27-2004 10:20 PM
Last minute jitters... saturnfreak01 General Saturn Discussion 28 03-21-2003 12:55 AM
this gets better by the minute... joeybagodonuts General Saturn Discussion 3 04-02-2001 09:38 PM
