Old 12-01-2000, 12:37 PM   #1
sc295
sc295 is on a distinguished road
Default rattling noise
ok its a 95 sc2 with 77,000 on it. I just got it back from the dealer about two weeks ago, I had the rings and such replaced for oil consumption. Now when ever the car is started up cold and the cluch is released there is a rattle the come from the rt ft somewhere. it happens if i let of the gass to slow down or get back on it to speed up with the flow of traffic. It happens only for an instent, but it is in all 5 gears, regardless of RPMs. when the car reaches operating temp. the noise stop. I'm taking it back hopefully on wed. but any suggestions would help.
thank you
Add to sc295's Reputation
Rate the quality of this post and help sc295 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sc295 is offline
Old 12-02-2000, 08:14 PM   #2
SilverPlumGirl
SilverPlumGirl is on a distinguished road
Default
read my post....re: rattling noise...(SilverPlumGirl) Dec 2/00
does it sound like the same problem????
If not ... I did have a weird springy-rattling..boinging noise in my
car and they replaced the "control assembly" and the "Glove Box Latch Assy"
It was coming some where from the front dash area...
Hope this helps
Add to SilverPlumGirl's Reputation
Rate the quality of this post and help SilverPlumGirl reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SilverPlumGirl is offline
Old 12-03-2000, 12:07 PM   #3
Abe95SC2
Abe95SC2 is on a distinguished road
Abe95SC2's Avatar
Default
It could the top engine mount. It's a cheap and easy fix. You can do it yourself in about 1/2 hour.
Abe.
Add to Abe95SC2's Reputation
Rate the quality of this post and help Abe95SC2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Abe95SC2 is offline
Old 12-04-2000, 02:35 AM   #4
sc295
Default
I don't think its a mount because then it would do it in nuteral, wouldn't it? it only hapens when it is in gear. It almost sounds as if something in the drive train is loose and then once the car is warm and at operating temp, it gets tight again.
sc295 is offline
Old 12-04-2000, 08:58 AM   #5
BobL
BobL is on a distinguished road
Default
Since you just had major engine work done, the dealer may have left something loose. Why waste your time on it. They should certainly make this right on service warranty.
Add to BobL's Reputation
Rate the quality of this post and help BobL reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
BobL is offline
Old 12-10-2000, 04:11 PM   #6
shekano
shekano is on a distinguished road
Default
I have the EXACT same problem. I can't figure it out and it was after I had service from the dealer. It's more apparent when I shift in the lower gears, like something is shakes.
Where you able to get it fixed, figure it out?
Add to shekano's Reputation
Rate the quality of this post and help shekano reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
shekano is offline
AC rattling noise liarliar17 S-Series Tech 7 03-11-2014 05:11 PM
A/C Rattling Noise mirandm S-Series Tech 15 07-08-2008 01:36 AM
AC Rattling Noise mirandm L-Series Tech 1 06-30-2008 12:26 PM
rattling noise max1 S-Series Tech 17 11-01-2004 11:15 PM
Rattling noise is still there Son93SL2 Miscellaneous Tech 6 08-15-2002 08:44 PM
