Old 11-12-2006, 08:31 PM   #1
saturnbomb
saturnbomb is on a distinguished road
Default first gen suspension
hey new here to saturns i got this car for a daily driver caus it was free and gets good gas milage then the tranny blew and the lotor was smoking so i did a twin cam swap and then i just did a custom turbo setup and now want to get some suspension stuff like strut bars sway bars and lowering coils and new struts and want to know what you guys have on your car what brands and how they handle thanks
1995 sl1 dohc turbo
Add to saturnbomb's Reputation
Rate the quality of this post and help saturnbomb reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
saturnbomb is offline   Reply With Quote
Old 11-12-2006, 08:48 PM   #2
WingsOfSaturn
WingsOfSaturn's Avatar
Default Re: first gen suspension
Could you rewrite that. Periods are your friend. I gave up after the first line.
97 SL2 AT 150K Original Owner
95 SL2 MT 220K+
My Saturns have BRASS ones!
Old 11-12-2006, 08:53 PM   #3
Uzzy
Uzzy's Avatar
2002 SC1
The DOHC cars had upgraded suspensions as far as sway bars go. Larger up front, and the SOHC cars, don't have one at all out back. Otherwise, the suspensions are pretty much the same on all the cars fom '91-'02.
Aut viam inveniam aut faciam
Add to Uzzy's Reputation
Old 11-12-2006, 09:30 PM   #4
saturnbomb
sorry. I want to know what people have done suspension wise to ther car. And how they handel with the upgrades. So the twin cams have a rear sway bar?
1995 sl1 dohc turbo
Old 11-12-2006, 09:44 PM   #5
WingsOfSaturn
A good setup is KYB struts and Eibach springs. Firms up the suspension but is still smooth enough for a daily driver. $20 strut bar off of ebay, some say that it does not help very much. But it does look neat.
95 SL2 MT 220K+
Old 11-12-2006, 09:48 PM   #6
eRic 02sc2
eRic 02sc2's Avatar
the suspension is the same on all S-Series (1991-2002). the twin cams had a bigger front sway bar and a rear sway bar. the single cams had a smaller front sway bar and no rear sway bar. the struts and springs are the same.
an excellent upgrade to the suspension would be KYB GR-2 struts and Eibach Pro-Kits springs that will lower the car without being so stiff that the ride beats you up over rough roads. a strut tower brace on the front helps.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 11-12-2006, 10:23 PM   #7
saturnbomb
so can i throw on a rear sway bar from a twin cam? and if so what needs to be done to do that?
1995 sl1 dohc turbo
Old 11-12-2006, 10:28 PM   #8
Uzzy
Uzzy's Avatar
2002 SC1
No, the plates where they bolt-up are missing, but if you can weld them on, or get the whole rear section and put it on, that would work, but you can't just bolt on on if it's not there. I've got the Eibach Pro-Kit, but just the stock shocks.
Old 11-12-2006, 10:33 PM   #9
saturnbomb
oh so i need to feb up some mounts and brackets for it then, sweet i have a weekend project thanks
1995 sl1 dohc turbo
Old 11-13-2006, 02:54 AM   #10
xupthree60
xupthree60 is on a distinguished road
xupthree60's Avatar
2002 L-Series 2.2L Sedan
dont forget to get the front sway bar from a dohc as well, its larger than whats on the sohc.
also u can get front strut bars on ebay for as little as $24 shiped, just get one thats solid, not with a bunch of holes in it. u dont really need a rear strut bar unless u are racing or have a wagon, since theres an accesory tray on the coupes and sedans u wont notice it unless ur racing.
kyb struts are pretty much ur only option in struts, and ur only good choices in springs are ebach or H&R sport. ebach for the street or H&R for race. they both drop about 1.3". if u wanna go lower than that u can but u will start having axle and cv problems.
i have stock front and rear sway bars and front and rear strut bars right now... if u wanna no how good that handles then...
i went to my first auto x race and got 2nd by 0.108 to a 06 mustang gt driven by a pro stock car driver, and beet the 3rd place (a 500hp 300zx) by 0.8something. i also have kyb stuts and H&R sport springs on the way, u can see my other mods in my sig
3x CFR SCCA autocross champion with a 95 SL2 & 98 SC2
Currently own a 02 L200 with no plans to mod.
Add to xupthree60's Reputation
Rate the quality of this post and help xupthree60 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
xupthree60 is offline   Reply With Quote
Old 11-13-2006, 11:34 AM   #11
Low Saturn
Low Saturn's Avatar
2007 AURA XR
Pics...
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2001 Chevrolet Suburban
-2007 Saturn Aura XR
1st Gen - 2nd Gen -3rd Gen Sedan Comparisons 2NDSOUT S-Series General 1 05-21-2008 08:24 AM
2nd Gen Rear Disc Brake Swap: 1st gen brakes fit? TIMSPEED S-Series Tech 4 02-19-2008 01:06 AM
retrofitting 2nd gen leather e-brake onto 3rd gen car dmc S-Series General 0 10-12-2007 06:31 PM
2nd Gen, 2nd Gen, 1st Gen, Now 3rd Gen... Red97sc2 S-Series Tech 1 03-13-2007 09:10 AM
2nd & 3rd gen catbacks on a 1st gen? Will it work? s-seriesguy S-Series Mods 4 09-05-2006 01:13 AM
