Old 10-18-2006, 11:32 AM   #1
cooleyblues
cooleyblues is on a distinguished road
2000 SL2
Default daytime running lights
i started my car the other day and the daytime running lights blink five or six times then shut off and haven't come back on. Any help?
Add to cooleyblues's Reputation
Rate the quality of this post and help cooleyblues reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cooleyblues is offline   Reply With Quote
Old 10-18-2006, 08:50 PM   #2
bluesl2
bluesl2's Avatar
Default Re: daytime running lights
Check both of your high beam headlamps, one of the bulbs may be burnt out.Also, if the bulbs are ok, check the headlamp fuses in the underhood fuse block. Sometimes the headlamp wires chafe on the headlamp brackets and blow fuses.
Add to bluesl2's Reputation
Old 10-19-2006, 12:14 AM   #3
eRic 02sc2
eRic 02sc2's Avatar
replace the DRL relay and see if that works.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 02-08-2016, 02:19 AM   #4
Laemjohnson
Laemjohnson is on a distinguished road
So I have disabled my daytime running lights by pulling the relay and soon discovered that the right high beam wasn't working so I put it back but now I have no drl and now the cooling fan does not kick in on its own anymore. Any suggestions on how to fix this.
Add to Laemjohnson's Reputation
Rate the quality of this post and help Laemjohnson reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Laemjohnson is offline   Reply With Quote
Old 02-10-2016, 10:53 PM   #5
toggenburg
toggenburg's Avatar
Welcome laemjohnson, err, um, you do realize you are posting onto a 2006 thread right?
There is zero connection between the DRL relay removal and replacement and your radiator fan.
The cooling fan only comes on:
- If your AC button is pressed to "ON" AND ambient temp is like above 45 degrees F.
OR - the AC is off, and your coolant temperature gauge is approaching 3/4 and nearly at the RED zone. (what year, mileage and model saturn do you own?).
Maybe the fan is shot, maybe you have a blown fuse, maybe the wiring or connector at the fan is broken/frayed or disconnected?
Daytime Running Lights kodak_jack Vue Tech 5 10-03-2007 10:14 AM
Daytime running lights out Monica Vue Tech 7 03-28-2007 12:07 AM
Daytime Running Lights. Jinjo S-Series General 15 06-03-2006 01:46 PM
Daytime Running Lights. Jinjo S-Series General 4 04-30-2006 09:55 AM
Daytime Running Lights out. astoria29 S-Series General 15 05-19-2005 11:47 PM
