Old 09-26-2006, 11:58 AM   #1
bigtoque
bigtoque has a spectacular aura aboutbigtoque has a spectacular aura aboutbigtoque has a spectacular aura about
Default I'm getting < 25 MPG in '02 SC2. Friend gets 40 MPG in '01 SC1 (even more on the HWY)
I just bought my car used from a Saturn dealership. It's got ~32,000 miles on it.
I haven't changed the oil yet since I got it from the dealership. I've only driven around 1500 miles in the 2 months I've had the car.
When I first got the car I was getting around 28-30 MPG. Now I'm getting 23-25 MPG.
What kinds of things could be causing this and how can I try to increase my gas milage?
Edit: One other thing... I was told that even though the SC2 is DOHC and SC1 is SOHC, they still get the same mileage. Is this true?
Add to bigtoque's Reputation
Rate the quality of this post and help bigtoque reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bigtoque is offline   Reply With Quote
Old 09-26-2006, 12:34 PM   #2
amazinghl
Default Re: I'm getting < 25 MPG in '02 SC2. Friend gets 40 MPG in '01 SC1 (even more on the HWY)
SOHC gets better gas milage because it makes less hp and have taller gearing.
Your EPA milge is rated 26/36 for manual and 24/34 for auto, so your gasmilage isn't that far off. Change the oil, change the ECTS (do a search) and do a tune up.
00 Insight 72mpg
Add to amazinghl's Reputation
Old 09-26-2006, 01:10 PM   #3
BarnOwl
BarnOwl's Avatar
An '02 should have the new style ECTS. So, it's unlikely to be an issue. If it's an automatic transmission change the transmission fluid and filter. The Saturn transmission has an external cannister filter just like an oil filter and a drain plug. So, it's no harder than changing the oil. Time for plugs. Check the coil towers to make sure they have no corrosion. Make sure your tires are inflated properly. However, the factor that has the largest effect on your mileage is how you drive. Fast starts and fast stop eat away at you mileage.
Add to BarnOwl's Reputation
Old 10-01-2006, 10:07 PM   #4
kickflipjr
kickflipjr is on a distinguished road
Well your gas milage may be different due to different types of driving or driving style. Check you tires too. If you drive a steady 50-55mpg on the highway I am shure you would get 40mpg or higher.
Add to kickflipjr's Reputation
Rate the quality of this post and help kickflipjr reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kickflipjr is offline   Reply With Quote
Old 10-01-2006, 10:13 PM   #5
lovemysan
lovemysan is on a distinguished road
2002 SL
Driving a lot in town with a cold engine on short trips will reduce mileage. One reason the mileage declined could be that the computer has retrimmed the air/fuel per your habits and conditions. Also if your using crummy gas switch to a better brand.
02 sl sport
5 spd
got 50mpg?
[url=http://www.gassavers.org][img]http://www.gassavers.org/gaslog/sig.php?id=127[/img][/url]
Add to lovemysan's Reputation
Rate the quality of this post and help lovemysan reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lovemysan is offline   Reply With Quote
Old 10-01-2006, 10:31 PM   #6
eRic 02sc2
eRic 02sc2's Avatar
02 SC2 was city/highway rated at 27/38 mpg manual, 25/36 mpg automatic
SC1 was rated at 28/40 mpg manual, 26/36 mpg automatic. your mileage may vary.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
58.25 Hwy. MPG! keautocenter S-Series Tech 79 06-08-2013 03:09 AM
Now up to 57.3 mpg at 60 mph in my 97 SC1 cheapybob S-Series General 26 10-10-2012 12:56 AM
Bad HWY MPG, "knocking like" noise missdeevi S-Series Tech 6 08-25-2009 01:18 PM
Epa & Mpg (hwy)??? darnell89 General Saturn Discussion 13 09-11-2008 09:15 PM
mpg in a '93 SC1 twosaturns S-Series General 2 03-19-2004 10:10 PM
