Old 09-08-2006, 11:55 PM   #1
klaus
klaus is on a distinguished road
klaus's Avatar
1997 SW2
Default 97 SW2 Lack of power when hot
I have a 97 SW2 with 222K. In the early morning and when the sun is going down at night, it seems to have plenty of HP. When the outside temp is warm and the car has been running for a bit, HP seems to be down and the car is doggish. AC on or off has only minor effect and engine temp as indicated on the guage is always OK.
Any ideas, or is this what I should expect from a car with this mileage?
Normal tune up stuff is up to date...plugs/wires, PCV, fuel filter, air filter. Fuel economy is 29-33MPG.
Thanks,
Chris
Add to klaus's Reputation
Rate the quality of this post and help klaus reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
klaus is offline   Reply With Quote
Old 09-09-2006, 12:57 AM   #2
WingsOfSaturn
WingsOfSaturn's Avatar
Default Re: 97 SW2 Lack of power when hot
Change or check your ECTS? Make sure is is the brass one.
97 SL2 AT 150K Original Owner
95 SL2 MT 220K+
My Saturns have BRASS ones!
Old 09-09-2006, 07:14 AM   #3
klaus
klaus's Avatar
1997 SW2
What is an ECTS?
Old 09-09-2006, 07:15 AM   #4
klaus
klaus's Avatar
1997 SW2
coolant temp sensor...duh...never mind!
Old 09-09-2006, 09:57 AM   #5
WingsOfSaturn
klaus: Made you look. Yea the ECTS, if the old plastic one, can cause all kinds of problems. It is usually the first item that forum members will ask new members if they have changed/checked it.
95 SL2 MT 220K+
Old 09-09-2006, 04:24 PM   #6
klaus
klaus's Avatar
1997 SW2
Where is it located? Is there an impedance measurement for testing? I have no engine codes, would it produce one if it were marginal.
Thanks...
Old 09-09-2006, 04:30 PM   #7
andy_95sl2
andy_95sl2 is on a distinguished road
andy_95sl2's Avatar
dont worry about the impedance test, because these things crack and dont send the right signal. Its located on the right side of the head, underneath the radiator hose. Should have a connector on it.
2004 Jeep Wrangler Rubicon -> daily & toy =)
2009 BMW 128i -> sold
2003 VW GTI 1.8T -> wrecked
1998 Saturn SL2 -> parted out
1995 Saturn SL2 -> sold
Add to andy_95sl2's Reputation
Rate the quality of this post and help andy_95sl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
andy_95sl2 is offline   Reply With Quote
Old 09-09-2006, 04:31 PM   #8
andy_95sl2
andy_95sl2's Avatar
http://www.saturnfans.com/forums/showthread.php?t=84939
Lack of Power...High RPMs sven1 L-Series General 6 06-01-2006 08:49 AM
lack of power problem and sputtering gypsy35 S-Series General 20 09-21-2005 10:56 PM
Running REALLY HOT and Extreme lack of power Silversaturn L-Series Tech 6 09-21-2005 08:21 AM
Lack of power radioouman S-Series Tech 3 01-09-2003 07:56 AM
lack of power saturn_guy S-Series Tech 2 05-11-2000 11:15 PM
