Old 08-15-2006, 11:59 AM   #1
Zero_DgZ
Zero_DgZ will become famous soon enough
Default Wiring Layout: Running Lights?
Here's a thought. Does anybody know of someplace to get ahold of wiring diagrams/layouts for an '02 SL2?
My car has the usual daytime running lights, which seem to be activated when the car is in gear (it's an auto) and the parking brake is off. I want to bypass this nonsense and just stick a switch on the convenient empty spot on my dash to turn the DRL's on and off.
Possible? Bad idea? Insanely complex?
Add to Zero_DgZ's Reputation
Rate the quality of this post and help Zero_DgZ reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Zero_DgZ is offline   Reply With Quote
Old 08-15-2006, 12:11 PM   #2
FuriousTrout
FuriousTrout is on a distinguished road
Default Re: Wiring Layout: Running Lights?
Why do you want a switch? It's easier just to do the DRL delete.
Anyways, if you really want a switch, do the delete by bending a pin on the relay out of the way, and then running that pin through a switch and back into where it originally should have gone. I don't remember which pin...I'm thinking 87, but that could be wrong....do some searching, I know Saturnspot has a stickied thread detailing the process.
Add to FuriousTrout's Reputation
Rate the quality of this post and help FuriousTrout reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
FuriousTrout is offline   Reply With Quote
Old 08-15-2006, 01:29 PM   #3
Zero_DgZ
Thanks, I'll check for it.
I want a switch so I can turn on the DRL's when I want to. For instance, when I'm delivering and I want to light up a customer's driveway but not blind people.
Old 08-15-2006, 02:13 PM   #4
FuriousTrout
No offense, but that's kind of a dumb idea. Just turn your parking lights on.
Old 08-15-2006, 02:20 PM   #5
The other night I was one of the last 3 cars going into a Drive in movie theater and would have liked to kill the DRLs so as not to annoy people. I wanted just the parking lights on, but the DRLs are on unless Low/High or parking brake are on. The driveway was potholed enough that I didn't wanna 1 click the parking brake.
Might be something to try though, and it requires 0 mods.
Old 08-15-2006, 05:49 PM   #6
saturn98
saturn98 is on a distinguished road
I believe if you put on the parking lights, the DRL go off.
Add to saturn98's Reputation
Rate the quality of this post and help saturn98 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
saturn98 is offline   Reply With Quote
Old 08-15-2006, 07:01 PM   #7
SaturnManiac
SaturnManiac's Avatar
I know on my 2000 SL2, the DRL's are off if it's in park or neutral.
Add to SaturnManiac's Reputation
Rate the quality of this post and help SaturnManiac reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 08-15-2006, 09:44 PM   #8
BigAl
BigAl is on a distinguished road
2007 ION-2 Sedan
why not just add a set of cheap driving lights on a toggle switch.
Add to BigAl's Reputation
Rate the quality of this post and help BigAl reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
BigAl is offline   Reply With Quote
Old 08-15-2006, 10:26 PM   #9
eRic 02sc2
eRic 02sc2's Avatar
Disabling DRL's. No tools, no jumper, no dash warnings.
http://www.saturnspot.com/forum/viewtopic.php?t=30951
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 08-15-2006, 11:09 PM   #10
Uzzy
Uzzy's Avatar
2002 SC1
They are off in park only, not neutral, unless they changed something from 2000 to 2002. They also don't turn off when the parking lights are turned on.
Aut viam inveniam aut faciam
Add to Uzzy's Reputation
Wiring Trailer Lights Snerdguy S-Series Tech 6 12-18-2015 09:40 AM
Night time running lights and dash lights fail Waterboy S-Series Tech 11 04-25-2012 01:35 PM
Lights wiring questions macman90 L-Series Tech 8 07-15-2009 11:30 PM
'01 reverse lights wiring KnockOut S-Series Tech 4 03-15-2007 05:19 PM
L200: Running wiring from battery to trunk knakonec L-Series Tech 0 04-11-2005 03:19 PM
