Old 08-05-2006, 01:51 PM   #1
mikes 1994 z28
mikes 1994 z28 is on a distinguished road
mikes 1994 z28's Avatar
Default brass fitting near oil cap on valve cover, where does hose go?
Ive got a '94 saturn sl1 SOHC. I just replace the head gaskets and got everything back together... except this brass fitting for some type of vacume hose. The fitting is on the back side of the valve cover near the top, nearest to the oil cap. I can't remember where the line runs to. Does it run to the back side of the throttle body?
Add to mikes 1994 z28's Reputation
Rate the quality of this post and help mikes 1994 z28 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mikes 1994 z28 is offline   Reply With Quote
Old 08-05-2006, 02:06 PM   #2
eljefino
eljefino's Avatar
1995 SW1
Default Re: brass fitting near oil cap on valve cover, where does hose go?
goes to another nipple on your air intake. Unless you have a cold air intake, in which case you usually toss a breather filter on there.
You should have a pcv valve that does go to your throttle body, this uses the other hole in your valve cover.
Add to eljefino's Reputation
Oil Around Valve Cover Gasket calirider S-Series Tech 11 08-15-2008 07:10 PM
valve cover oil leak phool S-Series Tech 15 02-13-2008 06:42 PM
Oil Leak? Not oil pan, not valve cover, not front oil seal. klcl S-Series Tech 14 10-05-2007 12:25 PM
Fram Oil Filters not Fitting the Oil Cap? Maritime Storm Ion Tech 1 07-14-2006 09:43 PM
valve cover to intake hose coming off... LI 350 S-Series Tech 19 07-06-2001 11:06 PM
