Old 08-01-2006, 02:43 PM   #1
xupthree60
xupthree60 is on a distinguished road
xupthree60's Avatar
2002 L-Series 2.2L Sedan
Default front exhoust pipe/down pipe, same thing?
yes or no?
"# Remove front exhaust pipe-to-manifold/header nuts. (1/2" socket needed)
# Remove front exhaust pipe-to-catalytic converter nuts. (1/2" socket needed)
# Remove exhaust pipe support bracket-to-exhaust pipe nuts. (1/2" socket needed)
# Remove front exhaust pipe from vehicle"
is it saying it want the down pipe to past the cat removed?
3x CFR SCCA autocross champion with a 95 SL2 & 98 SC2
Currently own a 02 L200 with no plans to mod.
Add to xupthree60's Reputation
Rate the quality of this post and help xupthree60 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
xupthree60 is offline   Reply With Quote
Old 08-01-2006, 02:51 PM   #2
amazinghl
Default Re: front exhoust pipe/down pipe, same thing?
If by front exhaust pipe you mean the pipe between the catalytic convertor and exhaust manifold then yes, it's the same thing as downpipe.
13mm socket. None of the bolts/nuts in your saturn is standard except maybe the bleeder valves.
Your downpipe might also be WELDED to the catalytic convertor. Be perpare to cut it, if it is welded.
00 Insight 72mpg
Add to amazinghl's Reputation
Old 08-01-2006, 02:57 PM   #3
andy_95sl2
andy_95sl2 is on a distinguished road
andy_95sl2's Avatar
on my car, the downpipe is welded to the cat, although about 4" after the cat there is a 3 bolt flange that connects it to the rest of the exhaust pipes. I'd just remove the entire exhaust if you're doing the swap anyway.. if its welded that is.
2004 Jeep Wrangler Rubicon -> daily & toy =)
2009 BMW 128i -> sold
2003 VW GTI 1.8T -> wrecked
1998 Saturn SL2 -> parted out
1995 Saturn SL2 -> sold
Add to andy_95sl2's Reputation
Rate the quality of this post and help andy_95sl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
andy_95sl2 is offline   Reply With Quote
Old 08-01-2006, 03:54 PM   #4
xupthree60
xupthree60's Avatar
yup got it thanks, i have one more question in a new thread if u go look at it then u can help me out some more lol
Old 08-01-2006, 04:54 PM   #5
Originally Posted by amazinghl
None of the bolts/nuts in your saturn is standard ..
Sure they are. Metric is more "standard" than SAE.
Add to madpogue's Reputation
flex pipe/ down pipe/ pipe... pipe adam2887 S-Series General 1 02-14-2009 11:10 AM
Front exhaust pipe cracked at pipe-to-engine stiffener clamp JohnHupp S-Series Tech 2 07-28-2007 11:18 AM
What size exhaust pipe for the flex pipe? turbobuick33 S-Series Tech 4 03-10-2007 04:46 PM
Down Pipe/Header Pipe/Flex Pipe/Front Pipe Carriere S-Series General 6 05-12-2006 08:44 PM
resinator question/tail pipe thing e.. Sattyinsnow Mods and Performance 1 07-03-2003 09:24 AM
