Old 04-28-2006, 09:43 PM   #1
Idouoooo
Idouoooo is on a distinguished road
Roll Eyes daytime runing lights and right high beam out
ok...so my 02 SL2 daytime runin lights went out and the right highbeam too. i checked the bulb and its fine...but the right high beam and daytime lights are not working...everything else works fine...traced the high beam wires back to the fuse box and it all looks good. all the fuses are good too. any ideas on what else i should check?
Add to Idouoooo's Reputation
Rate the quality of this post and help Idouoooo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Idouoooo is offline   Reply With Quote
Old 04-28-2006, 09:56 PM   #2
eRic 02sc2
eRic 02sc2's Avatar
Default Re: daytime runing lights and right high beam out
replace the DRL relay.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 04-28-2006, 10:28 PM   #3
wolfman
wolfman's Avatar
He's probably right. You can find out for sure by simply swapping the DRL relay with one of the others in the UHJB (Under hood fuse box) and see if that resolves the problem. If it does, THEN go buy a new DRL relay.
Add to wolfman's Reputation
Old 04-28-2006, 11:05 PM   #4
Idouoooo
ok, will try and get back to you guys...
Old 01-18-2007, 02:48 AM   #5
benkulka
benkulka is on a distinguished road
benkulka's Avatar
ok . apologies on reviving and old thread. but i have the same exact problem . however i purposley removed my DRL relay so i wouldnt have my DRLs on. but i still would love my right highbeam back.
could i possibly keep them off while getting back my highbeams?
if not i can live. i added a pair of foglights that help, but on those midnight munchie runs on them back roads, it sure would be nice to have a pair of bright lights to go with my foggies
again my apologies for this damn old thread.
Its a 4 door Satty
Add to benkulka's Reputation
Rate the quality of this post and help benkulka reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
benkulka is offline   Reply With Quote
Old 01-18-2007, 07:26 AM   #6
BarnOwl
BarnOwl's Avatar
Yes, go to the How-To Library (Use forum jump at the bottom of this page.) and do a search for DRL. You just need to add a jumper wire to make it work.
Add to BarnOwl's Reputation
Old 01-18-2007, 09:08 AM   #7
S3aturnR
S3aturnR's Avatar
1999 SL1
when i rigged my drl to a switch so i could turn them on whenever i wanted, the right hi-beam would not work when i left the drl on. sounds like you possibly have a ground problem or your drl relay is bad...
s3aturnr
Add to S3aturnR's Reputation
Old 01-19-2007, 12:56 PM   #8
97coupe
97coupe is on a distinguished road
Do remember though that when you select DRL mode that both lights are placed in series on that model Saturn so if one bulb is burned out the DRL's will not work because there is a open circuit. I tend to think there is a bad bulb here.
Add to 97coupe's Reputation
Rate the quality of this post and help 97coupe reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
97coupe is offline   Reply With Quote
High Beam comes on... Cincy Saturn L-Series General 10 01-20-2008 03:11 PM
Low Beam, but no high beam deligh387 L-Series General 6 12-08-2007 06:30 PM
What to do high beam lights? SL2-Guy S-Series Tech 4 09-01-2007 11:17 AM
Fog lights & high-beam headlights Doc_Floyd Vue General 9 04-15-2006 10:55 PM
Replacing Daytime Running Lights/High Beams... RustyJCNC Mods and Performance 8 08-28-2002 06:55 PM
