Old 04-14-2006, 04:03 PM   #1
Doc_Floyd
Doc_Floyd is on a distinguished road
Default Fog lights & high-beam headlights
Because Texas is a jurisdiction which would not prohibit running fog lights and high beam headlights simultaneously, can anyone advise procedures for modification of the fog light relay to permit such?
Add to Doc_Floyd's Reputation
Rate the quality of this post and help Doc_Floyd reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Doc_Floyd is offline   Reply With Quote
Old 04-14-2006, 09:35 PM   #2
impaler
impaler is on a distinguished road
impaler's Avatar
2006 ION Red Line
Default Re: Fog lights & high-beam headlights
If it's prohibited, why would you want to allow it? Did you buy a vehcile in TX and no longer live there? I'm in Texas, as well, so I'm curious.
The Impaler
'06 ION Red Line (black)
'06 VUE AWD V6 (black)
'04 ION-3 Quad Coupe (silver)
'97 SC2 (green)
Add to impaler's Reputation
Rate the quality of this post and help impaler reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
impaler is offline   Reply With Quote
Old 04-14-2006, 11:37 PM   #3
wolfman
wolfman's Avatar
It's not prohibited in Texas. (At least that is what he said) I'm thinking on it now. In OEM trim, the Foglights are controlled and monitored by the BCM (Body Control Module) So this may not be as easy as it might seem. I do not have the wiring diagram available to me at the moment, so I am hessitating trying to just say someting like "Connect wire A to wire B" for fear of frying the $$$ BCM in the process. I'll try to get back to you in the next few days.
Add to wolfman's Reputation
Old 04-15-2006, 01:49 AM   #4
fotovue
fotovue will become famous soon enough
fotovue's Avatar
2007 VUE Red Line
wolfman, what about rewiring the fog lights directly to bypass the bcm's control, like you wrote up once previously? I'm interested in finding a way to get the low beams to stay on with the high beams, if you can figure that one out while you ponder Doc_Floyd's request. I was thinking that with the fogs i'd best just re-wire it around the bcm like you did for yours, but if you have another idea, i'm interested to hear it also.
I'm hoping to eventually have it where I can have my fog lights, high beams, and low beams on at the same time. I'm also wanting to make the corner lights blink with my turn signals. I think I need a bigger battery.
Edit to add: sorry to hijack the thread doc!!!
2004 RL VUE AWD Black *R.I.P. 07/01/06* 65k
The 1st sold, 49th built
2007 RL VUE FWD Black *Born 01/26/07* 100k
mods: 4 wheel disc brakes, window tint, spoiler, blues and twos
Add to fotovue's Reputation
Rate the quality of this post and help fotovue reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
fotovue is offline   Reply With Quote
Old 04-15-2006, 02:25 AM   #5
wolfman
wolfman's Avatar
My 05 has traction control, so no OEM foglights (uses the place for the Foglight Switch for the traction control switch) The OEM foglights on my Vue were purchased on EBay and wired in with an aftermarket switch and two relays (so that they function as the OEM ones do) I am not sure if the BCM checks the Foglight circuit for a return (flow-through voltage) from the Foglights even when they are off to "look" for a malfunction or not. This is what I need to check. If the fogs are disconnected from the OEM harness and wired independant of the BCM (like mine are) it may cause the BCM to set a wrench light code as the return signal will vanish when the harness plugs are undone. Likewise feeding voltage back through the OEM harness by wiring the fogs to stay on with the high beams may send the wrong polarity voltage back through the BCM circuit and possibly damage the BCM.
Old 04-15-2006, 10:51 AM   #6
Doc_Floyd
Thanks, then disregard. I read elsewhere that the BCM does monitor this circuit and it is not as simple as many previous vehicles to modify. But it was worth an inquiry.
Old 04-15-2006, 07:23 PM   #7
runerx
runerx is on a distinguished road
runerx's Avatar
2003 VUE 2.2L
My Hellas are wired this way. I would imagine that the easiest way would be to wire it as if they were aftermarket. A side note the highbeams drop the voltage to one side of the light to turn them on. Otherwise they have equal power to both sides when they are off. Made wiring them fun!!!
Dave
Add to runerx's Reputation
Rate the quality of this post and help runerx reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
runerx is offline   Reply With Quote
Old 04-15-2006, 08:37 PM   #8
bigc791
bigc791 is on a distinguished road
bigc791's Avatar
1994 SL1
Couldnt he just use a relay that is turned on by the high beams to turn the fogs on. The only thing the bcm monitors is the control side of the relay for the fog lights. By using a second relay in a second circuit nothing would be back fed to the bcm since its not physically on the same circuit. The back feed would only goto the switch side of the relay which will be open anyways not allowing any current back any further.
Carmen
1998 2.4L swapped Plymouth neon is my ride.
Add to bigc791's Reputation
Rate the quality of this post and help bigc791 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bigc791 is offline   Reply With Quote
Old 04-15-2006, 10:16 PM   #9
Doc_Floyd
The logic of what you suggest makes sense, but it may be the easier in the saying than in the doing. It sounds like (a) I need a conventional relay, (b) to find the power feed for the high beams, (c) tap into it and connect to pole 85 on the relay, (d) ground the relay to 86, (e) fuse connect 30 to the battery or to the 30 connector on the original relay, (f) connect 87 to the fog lights or to 87 on the original relay.
Is that close? Wolfman what do you think?
flj
Old 04-15-2006, 10:55 PM   #10
bigc791
bigc791's Avatar
1994 SL1
That is correct. I dont have the schematic in front of me though so it is all being said based on memory.
Carmen
DRL & High Beam Light Wiring macman90 L-Series Tech 9 05-31-2009 03:19 PM
No high beam headlights right side 97 sl2 WJ33 S-Series Tech 3 12-24-2008 05:51 PM
What to do high beam lights? SL2-Guy S-Series Tech 4 09-01-2007 11:17 AM
daytime runing lights and right high beam out Idouoooo S-Series General 7 01-19-2007 12:56 PM
Headlights, Fog lights, oh my! JDub99SL2 S-Series Mods 1 06-25-2003 07:31 PM
