Old 03-11-2006, 05:29 PM   #1
snakeeye
snakeeye is on a distinguished road
Default Spark Plug Change--Washer or No Washer?
I just bought some Autolite Copper Core spark plugs (Part Number: 3926) for my '01 SL1 1.9L SOHC 4. The plugs came with washers, and I was wondering if I need to use them? Any help would be greatly appreciated. Thanks!
Add to snakeeye's Reputation
Rate the quality of this post and help snakeeye reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
snakeeye is offline   Reply With Quote
Old 03-11-2006, 05:36 PM   #2
RalliArt16
RalliArt16 is on a distinguished road
RalliArt16's Avatar
1996 SC1
Default Re: Spark Plug Change--Washer or No Washer?
Use em. They're crush washers, i believe they are there to make sure the spark plug seats properly
1996 SC1
Add to RalliArt16's Reputation
Rate the quality of this post and help RalliArt16 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RalliArt16 is offline   Reply With Quote
Old 03-11-2006, 05:41 PM   #3
redkees@msn.com
redkees@msn.com is on a distinguished road
redkees@msn.com's Avatar
2004 VUE 2.2L
2008 AURA XE
I always install the washers and coat spark plug threads with anti-seize.
Install your plugs when engine is cold. I took an old spark plug boot from an old set of wires-I use that to hand tighten or screw the splark plugs in. Great for removing old plugs after you first loosen with ratchet.
The washers are there to ensure you don't over tighten and strip the threads
of spark plug hole.
Add to redkees@msn.com's Reputation
Rate the quality of this post and help redkees@msn.com reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
redkees@msn.com is offline   Reply With Quote
Old 03-11-2006, 05:55 PM   #4
Welcome to the Board.
Yes use the washers. Basicly they are gaskets.
Add to ssicarman's Reputation
Old 03-12-2006, 04:12 PM   #5
Luke
Luke's Avatar
Default Old Boot used for extracting and inserting a plug
> Fm Redkees <
Great for removing old plugs after you first loosen with ratchet. <
That's exactly what I do, for by using the old boot, with the plug wire fully pulled out,
it allows one to better center the plug when initially installingit. Works very well.
Add to Luke's Reputation
Luke is offline   Reply With Quote
Old 03-12-2006, 08:07 PM   #6
Sky King
Sky King's Avatar
I agree with the concensus, use them. Some plugs come with washers. Those that don't generally have tapered seats. The engine/head is configured to use either a plug with a washer OR a tapered seat. A tapered seat plug will not seal right in a head intended to use a plug that takes a washer and vis-versa.
Add to Sky King's Reputation
Rate the quality of this post and help Sky King reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 03-12-2006, 08:34 PM   #7
dream36realms
dream36realms is on a distinguished road
dream36realms's Avatar
Nice first post Welcome aboard lol(always wanted to say that)
Add to dream36realms's Reputation
Rate the quality of this post and help dream36realms reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dream36realms is offline   Reply With Quote
Spark Plug Change for Astra cschmidt1956 Astra Tech 92 10-14-2019 05:16 PM
Spark Plug Change beensmoked L-Series General 8 05-19-2011 02:06 AM
Drain plug crush washer? (3.5l) ls3ftw Vue Tech 13 09-22-2009 11:01 PM
Drain Plug Washer help The Critic S-Series Tech 17 09-05-2007 05:06 PM
Oil drain plug washer... Craig S-Series General 8 10-01-2006 09:29 PM
