Old 01-17-2006, 04:55 PM   #1
RMracing125
RMracing125 is on a distinguished road
Default top speed
i hit 120mph the otherday and when i got to 120 and the cars top speed regulator kicked in.
what can i use to take that off...
Add to RMracing125's Reputation
Rate the quality of this post and help RMracing125 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RMracing125 is offline   Reply With Quote
Old 01-17-2006, 05:07 PM   #2
amazinghl
Default Re: top speed
It's a piece of software. So far nobody cracked it and I doublt anybody will.
Unless you go and buy, build, wire, and program megasquirt or any other aftermarket computer, you're not going to be going faster than what you governor says.
And I hope you're not doing this on public road.
00 Insight 72mpg
Add to amazinghl's Reputation
Old 01-17-2006, 05:08 PM   #3
BarnOwl
BarnOwl's Avatar
An aftermarket programable PCM. Unless, you've modded the engine to take it, I strongly advise against it.
Add to BarnOwl's Reputation
Old 01-17-2006, 05:10 PM   #4
adhhaahok
adhhaahok is on a distinguished road
adhhaahok's Avatar
1993 SC2
120 mph in a car made of plastic seems fast enough to me. that is only my opinion, though. i wouldnt try to get much faster than that. not in a saturn, anyway.
If you baby your car, it will baby your wallet...If you abuse your car, it will abuse your wallet.
1993/1995 SC2. You decide. http://www.cardomain.com/ride/2234915
Add to adhhaahok's Reputation
Rate the quality of this post and help adhhaahok reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
adhhaahok is offline   Reply With Quote
Old 01-17-2006, 05:16 PM   #5
JADEDSL2
JADEDSL2 will become famous soon enough
JADEDSL2's Avatar
Location: Sullivan, Missouri, USA, North America, Northern West Hemisphere, Earth, Solar System, Left Galactic Arm, Milky Way Galaxy, Local Galactic Cluster, Universe
1993 SL2
1991 SL2
I do believe that a first gen coupe with a certain type of wheels and a manual tranny can do 130 ish? Factory. Someone correct me. If you want faster than that, about all you can do without doing a custom PCM, is to get a computer out of an automatic for the same year, and put in the manual transmission out of a single cam saturn of the same year, and get some taller tires. If you're lucky, you'll probably hit 145 mph, before your car explodes and destroys itself from the governor and rev limiter being non existent. Good luck with that.
"1G8ZJ5472MZ134321"-my Jaded, I will never forget.
"1G8ZF5594PZ249184"-Trinity, for three are now one.
Add to JADEDSL2's Reputation
Rate the quality of this post and help JADEDSL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JADEDSL2 is offline   Reply With Quote
Old 01-17-2006, 05:20 PM   #6
DarrylLeeOHS30
DarrylLeeOHS30 is on a distinguished road
2001 SL2
what exactly happens when the ''speed govenor'' kicks in?
-Darryl
Add to DarrylLeeOHS30's Reputation
Rate the quality of this post and help DarrylLeeOHS30 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DarrylLeeOHS30 is offline   Reply With Quote
Old 01-17-2006, 05:58 PM   #7
JADEDSL2
JADEDSL2's Avatar
1993 SL2
1991 SL2
Someone chime in if I'm wrong, but I do believe it cuts fuel at the "governor" limit.
Old 01-17-2006, 08:11 PM   #8
koolkash_45
koolkash_45 is on a distinguished road
correct it cut the engines fuel supply.
Add to koolkash_45's Reputation
Rate the quality of this post and help koolkash_45 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
koolkash_45 is offline   Reply With Quote
Old 01-17-2006, 08:33 PM   #9
Admiral Beez
Admiral Beez is on a distinguished road
Admiral Beez's Avatar
2000 SL2
I've hit the limit once, going downhill in the TransCanada in NB, with no one around. I didn't even mean to do it, as I was cruising at 140 kph, when I started going downhill and accelerated, with the speed cut off coming on. However, I surely did not hit 193 kph (120 mph).
Add to Admiral Beez's Reputation
Rate the quality of this post and help Admiral Beez reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Admiral Beez is offline   Reply With Quote
Old 01-18-2006, 12:19 AM   #10
eRic 02sc2
eRic 02sc2's Avatar
Happy Re: top speed
when you bump against the 124 MPH limiter, the fuel injectors switch OFF momentarily until you slow down, then they switch back ON again. if you continue to do this 2 or 3 more times, the PCM may shut the engine OFF completely and you will coast down from 124 MPH in silence. Don't ask how I know this...
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 01-18-2006, 12:24 PM   #11
JADEDSL2
JADEDSL2's Avatar
1993 SL2
1991 SL2
Eric, I don't think anyone HAS to ask how you know that!
Old 01-18-2006, 12:35 PM   #12
iheartmysaturn
iheartmysaturn is on a distinguished road
iheartmysaturn's Avatar
1993 SL2
my wagon has seen somewhere between 120 and 130 not sure exacly how fast i was a little distracted
~1993 Saturn SL2m
Add to iheartmysaturn's Reputation
Rate the quality of this post and help iheartmysaturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
iheartmysaturn is offline   Reply With Quote
Old 01-18-2006, 12:37 PM   #13
JADEDSL2
JADEDSL2's Avatar
1993 SL2
1991 SL2
Originally Posted by iheartmysaturn
my saturn wagon has seen somewhere between 120 and 130 not sure exacly how fast i was a little distracted
Nice. Highest I got in my 91 was 110. Squeezed past the 108 limiter for a split second. I would've hit 130, but due to my "wonderful" geartooth rims, it was programmed low at the factory.
Old 01-18-2006, 01:14 PM   #14
S3aturnR
S3aturnR's Avatar
1999 SL1
nothing. don't try it...
s3aturnr
Add to S3aturnR's Reputation
Old 01-18-2006, 01:46 PM   #15
sickcallawayc12
sickcallawayc12 is on a distinguished road
sickcallawayc12's Avatar
who did you pay $20 to take that pic for you in your car?
1998 Chevrolet Blazer LT
all stock for now (nothin' wrong with that either)
I'll miss my Saturn, from the AEM CAI to the rear main oil seal leaks to the giant APC stickers on the side (sarcasm)
Add to sickcallawayc12's Reputation
Rate the quality of this post and help sickcallawayc12 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sickcallawayc12 is offline   Reply With Quote
Old 01-18-2006, 01:55 PM   #16
At what speed are the tires rated?
Add to madpogue's Reputation
Old 01-18-2006, 02:05 PM   #17
sickcallawayc12
only a cop would distract me at 120.
Old 01-18-2006, 02:10 PM   #18
JADEDSL2
JADEDSL2's Avatar
1993 SL2
1991 SL2
I think I recall he took that picture himself, aiming the camera without looking through it. Got a lucky shot. Is that right Eric?
Old 01-18-2006, 02:17 PM   #19
sickcallawayc12
At 125? I wouldn't have the guts to take my hands off the wheel. nice pic eric.
Old 01-18-2006, 02:20 PM   #20
JADEDSL2
JADEDSL2's Avatar
1993 SL2
1991 SL2
I'd do it, on a straight stretch. But my car ran in a true straight line for up to, oh say, 600 yards. It was nice. I hardly ever had to do those tiny little steering adjustments. I just held the wheel in one position, and it drove straight. Even if I let go, it still did.
Top Speed? TonyBaloney Astra General 26 09-16-2009 04:48 PM
Top Speed ? fred2003 L-Series Tech 13 08-17-2006 08:01 AM
Top Speed? ELewandowski Ion General 22 03-22-2006 05:56 PM
Danger: High speed thread! Top speed on L300V6 and 2.2 -ecotec? 2k3L300HID L-Series General 64 03-10-2005 11:53 PM
RL your top speed so far amishland Ion Red Line 40 11-25-2004 06:38 AM
