Old 11-23-2000, 02:21 PM   #1
BillyBob
BillyBob is on a distinguished road
Default Headlight Wiring
I've just replaced the headlights on my '95 SC2 with Bosch E-Code and 100/80W H4's, and am trying to figure out how to wire the new relays into the existing switch/dimmer. Saturn wiring is not what I expected, in that +12V runs directly to the headlights (thru a fuse) and the switch/dimmer closes the circuit on the negative side. What complicates things is that the headlight door circuit is thrown in somewhere along the line.
The double relay I'm using has a common ground, and I've tested the new wiring and lights by jumping the relays from the positive terminal of the battery. Do I need isolated ground relays, (2 terminals per relay) and how do I keep the door circuit? I guess another option is to just use the existing wiring with the 100W bulbs, but I was concerned about some of the comments I've read on this site about noticeably warm switches, apparently with the stock headlights. Anyone successfully using 100W bulbs with the stock wiring?
BTW, for those of you lucky enough to have '96 or older SC2's, this conversion makes a huge difference in light output and beam pattern. Easily the best lights I've had on any of my cars.
Thanks in advance.
Add to BillyBob's Reputation
Rate the quality of this post and help BillyBob reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
BillyBob is offline
Old 11-23-2000, 11:03 PM   #2
Default
Try using the relays with a battery source to power the lights with the factory wiring to trigger the relays. It could be a tricky fix. This way you can probably leave the pop up headlamp function the way it is. I've never seen anyone do this so good luck and use commom sense to wire it up. Also fuse the hell out of all the power wires.
Add to ssicarman's Reputation
ssicarman is offline
Old 11-24-2000, 12:19 AM   #3
Abe95SC2
Abe95SC2 is on a distinguished road
Abe95SC2's Avatar
Default
Use the leads that go to the headlights themselves to trigger the relays. Then use 10 guage wire on the high current side of the relays. That way when you turn on the lights the power from the headlight wiring will activate the relays and let the power flow without screwing with the headlight door electricals.
Suggestion. Take your high current side power directly from the alternator. This will greatly increase your lights output.
Abe.
Add to Abe95SC2's Reputation
Rate the quality of this post and help Abe95SC2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Abe95SC2 is offline
Headlight Wiring Harness Recall quint9 Outlook General 36 08-07-2012 11:13 AM
headlight wiring diagram 06_Ion2 Ion Mods 10 01-07-2012 05:32 PM
96 SL2 Halo Projector Headlight wiring..... dsnider420 S-Series Mods 21 03-11-2009 01:04 AM
Wiring... dracar S-Series Tech 5 06-09-2007 11:30 PM
2001 SC2 wiring diagram? (trailer wiring harness) gumpish S-Series General 1 05-01-2005 12:45 AM
