Old 01-31-2005, 05:15 PM   #1
JTB
JTB is on a distinguished road
Default Thrown diff pin
I have a 95 Saturn sc2 and have thrown my diff pin through the casing side.My question is, can I remove the transmission through the drivers side wheel well and not have to remove the engine and tranny as one piece? I would perfer to leave the engine in place and only remove the tranny.My book says to remove them as a unit. It is a 5 speed, if that makes a difference. Any help on the matter would be great.
Add to JTB's Reputation
Rate the quality of this post and help JTB reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JTB is offline
Old 01-31-2005, 05:28 PM   #2
Kevin94SL
Kevin94SL is on a distinguished road
Kevin94SL's Avatar
2006 ION-3 Sedan
Default Re: Thrown diff pin
Unsure about the removal myself. I know we did do a tranny in a '95SL1 with a 5 speed, but we had it done at a local shop. I don't think they pulled the engine, but they do have hoists and more equipment then most "driveway" mechanics have.
Best of luck with this venture.
Kevin
Add to Kevin94SL's Reputation
Rate the quality of this post and help Kevin94SL reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Kevin94SL is offline
Old 01-31-2005, 05:49 PM   #3
TheSaturnKid
TheSaturnKid is on a distinguished road
TheSaturnKid's Avatar
http://www.differentracing.com/tech_...anny_swap.html
not exactly what you are looking for, but yes, you can just drop the trans without removing the engine.
I feel your pain. Ive had the pin thrown twice.
Once I had it replaced by the saturn dealer, to the tune of 2K$
About 10K miles later, again, but did DIY, and cost about 750$
Has been good for 30K+!
Add to TheSaturnKid's Reputation
Rate the quality of this post and help TheSaturnKid reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TheSaturnKid is offline
Old 01-31-2005, 07:36 PM   #4
JTB
I have the shop space and a hoist for the car, I'm not sure from what way i should tackle this yet though, either from the top, bottom or side. Wondering what way will be the easiest.The used tranny is setting my son back 450 and the labor I am donating.I have done a Buick Regal (no picnic) but never a Saturn.
JTB is offline
Old 01-31-2005, 07:36 PM   #5
amazinghl
Weld the damn thing.
Add to amazinghl's Reputation
amazinghl is offline
Old 01-31-2005, 07:45 PM   #6
JTB
it will be welded this time
JTB is offline
Old 01-31-2005, 08:05 PM   #7
myoung
myoung is on a distinguished road
myoung's Avatar
i pulled it without completely dropping the cradle, so it can definately be done. it's a really tight fit, you'll want to get the cradle down 4-6" on the drivers side, which means losing both bolts on that side, and taking them down really far on the passenger side. you have to remember to disconnect the steering linkage from the rack by pulling up the rubber cover and removing a bolt (11 mm?). I can help more if you need it, but i can assure you that the cradle doesn't have to come out.
Add to myoung's Reputation
Rate the quality of this post and help myoung reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
myoung is offline
Old 01-31-2005, 10:32 PM   #8
wolfman
wolfman's Avatar
There are INSTRUCTIONS in the "How To" section on how to remove the manual transaxle out the bottom without pulling the engine. LINK: http://www.saturnfans.com/forums/showthread.php?t=29795
Add to wolfman's Reputation
wolfman is offline
Diff pin saturncrzy S-Series General 1 05-05-2009 05:45 PM
Diff Pin... mk43 S-Series Tech 3 11-01-2007 06:57 AM
Differential Pin (DIFF PIN) Inspection richpin06 S-Series Tech 4 03-21-2007 11:30 PM
Diff Pin Slammed_Saturn S-Series Tech 2 01-04-2006 08:26 PM
Diff Pin how to? alfieferenzo84 S-Series General 5 11-02-2005 02:05 PM
