Old 08-24-2004, 07:45 PM   #1
RexSpeed
RexSpeed is on a distinguished road
RexSpeed's Avatar
Default Rear speaker removal, 1st gen.
I bought some new speakers over the weekend thinking they'd be a snap to install. Turns out the factory grilles need to come off to do the job. So how do you get those blankety-blank lock rings off the plastic pegs without breaking them? I want to keep my factory speaker grilles but can't them off without risking the pegs breaking. Help.
Add to RexSpeed's Reputation
Rate the quality of this post and help RexSpeed reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RexSpeed is offline
Old 08-24-2004, 08:29 PM   #2
71_307
71_307 is on a distinguished road
Default
there is a way but i just dont no how.. i jsut ripped it out nicely and placed it back.. so its not really held in there tight but it doesnt rattel or anything..
Add to 71_307's Reputation
Rate the quality of this post and help 71_307 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
71_307 is offline
Old 08-24-2004, 08:53 PM   #3
the_skin_eater
the_skin_eater is on a distinguished road
the_skin_eater's Avatar
1999 SL1
Default
take off the back cardboard thingy on top(if its like the 2nd gen) there should be little plastic screws in the front behind the seats, just push from the other side till they start to pop out, then get pliers or sumptin to fit in and pull em out...then bolts for the grills are under the back shelf
Im not crazy, just bored...
http://www.cardomain.com/id/the_skin_eater ---Chek it out.
All my time goes to the Talon...My girlfriend is jealous. But my car is jealous that I sleep with her...
Add to the_skin_eater's Reputation
Rate the quality of this post and help the_skin_eater reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
the_skin_eater is offline
Old 08-24-2004, 08:58 PM   #4
RexSpeed
RexSpeed's Avatar
Default
Tried that, the grilles aren't bolted in though. They have pegs molded in and are held to the parcel shelf with little one-way washer-lock thingies.
If it were 1994 and I had to have the dealer replace a speaker, how would they do it? Anyone? Anyone?
RexSpeed is offline
Old 08-24-2004, 09:33 PM   #5
M.Nguyen
M.Nguyen is on a distinguished road
M.Nguyen's Avatar
1993 SL2
Default
you've gotta remove the whole rear deck. You cannot just pull out the speaker grills and put the speakers in.
Fold your seat down. then remove the two plastic pieces behind the cusion that holds the rear deck. Then push up in the center.
pull out.
Add to M.Nguyen's Reputation
Rate the quality of this post and help M.Nguyen reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
M.Nguyen is offline
Old 08-24-2004, 10:05 PM   #6
lilcraigford
lilcraigford is on a distinguished road
Default
pull out.
On my 1994 I also had to remove rear pillars, they overlapped the "speaker deck" (wasn't a big deal though, they're just clipped in). Then I just removed the plastic pins with a screwdriver, slipped the seat-belts through the slots and lifted the piece up and out of place.
'94 SL2: The Detail Junky (Will it ever run? Does it even exist?)
'95 SW2: The Daily Junky 3 (380k Champion)
http://thedetailjunky.blogspot.com/
Add to lilcraigford's Reputation
Rate the quality of this post and help lilcraigford reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lilcraigford is offline
Old 08-24-2004, 10:26 PM   #7
wolfman
wolfman's Avatar
Default
On your back, rear seats laid down, wiggle and turn the metal sped nuts off the plastic grill studs, then lift the rear speaker grills off the top of the rear package shelf. The speed nuts BOTH retain the grills AND the speakers.
Add to wolfman's Reputation
wolfman is offline
Old 08-24-2004, 11:25 PM   #8
erick295
erick295 is on a distinguished road
erick295's Avatar
Default
I got my deck off without removing the pillar trim by just forcing it out. It took me about 5 minutes to take it out and put it back in. Installing the speakers and baffles was actually harder than removing the deck. I have a '95 SL1.
Add to erick295's Reputation
Rate the quality of this post and help erick295 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
erick295 is offline
Old 08-25-2004, 01:03 AM   #9
s-seriesguy
s-seriesguy will become famous soon enough
Default
I cut them off. You can buy the nuts at auto zone for like a nickel each.
Add to s-seriesguy's Reputation
Rate the quality of this post and help s-seriesguy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
s-seriesguy is offline
Old 08-25-2004, 06:50 AM   #10
ParisTom
ParisTom is on a distinguished road
ParisTom's Avatar
1992 SC
Default
I just destroyed mine, chances are the grilles that come with your new speakers are nicer anyways. Plus, if they're 2+ way you might have an issue with clearance.
Add to ParisTom's Reputation
Rate the quality of this post and help ParisTom reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ParisTom is offline
Old 08-25-2004, 04:20 PM   #11
Tuanies
Tuanies is on a distinguished road
Default
I cut them off and used my speaker grilles.
My G1 with the Infinity and Alpine grilles.
Add to Tuanies's Reputation
Rate the quality of this post and help Tuanies reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Tuanies is offline
Old 08-25-2004, 10:18 PM   #12
epicdori
epicdori is on a distinguished road
Default
I kept my factory grills because even though I have almost limo tint, theft is always a big problem. For the same reason, I did not dash mount my removable tweeters. If someone can look in and see somehing aftermarket, then they may decide it is worth the effort to break in.
Add to epicdori's Reputation
Rate the quality of this post and help epicdori reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
epicdori is offline
Old 08-25-2004, 10:36 PM   #13
RexSpeed
RexSpeed's Avatar
Default
Exactly the reason I wanted to salvage my OEM grilles; stealth. I did manage to save them. It took me a little time and a lot of swearing, but I got all 6 of those stupid lock rings off and only broke one peg.
Now if I can only devise a way to re-mount them that won't be such a PITA the next time I need to get them off.
Thanks for all the input
RexSpeed is offline
Old 08-26-2004, 07:20 AM   #14
Tuanies
Default
I just have a two way pager alarm and there are two blinking LED's in my dash, secure enough for me.
Tuanies is offline
2nd Gen Rear Disc Brake Swap: 1st gen brakes fit? TIMSPEED S-Series Tech 4 02-19-2008 01:06 AM
96 SL2 rear speaker removal APE992 S-Series General 8 02-01-2006 09:06 AM
SC! rear speaker removal Red_SC1 S-Series General 6 10-14-2005 10:41 AM
Speaker Installation for 1st Gen SL2 JOKERSL2 S-Series General 1 02-15-2005 08:33 PM
WTB Rear Door Actuators - 1st GEN SL Applefool Classifieds 0 08-27-2003 08:32 AM
