Old 08-14-2004, 08:03 PM   #1
SLeepr
SLeepr is on a distinguished road
SLeepr's Avatar
Default Wheel Bearing/Hub assembly
I'm curious to whether an OEM hub assembly includes the wheel bearing or not (front). I have a bad bearing and am considering changing both (one alignment and don't have to mess with it twice). What's the best option to avoid having to press the suckers?
Add to SLeepr's Reputation
Rate the quality of this post and help SLeepr reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SLeepr is offline
Old 08-14-2004, 08:07 PM   #2
wolfman
wolfman's Avatar
Default
The hub ASSEMBLY (if purchased from Saturn anyway) will include installed bearings as is ready to bolt into place.
Add to wolfman's Reputation
wolfman is offline
Old 08-17-2004, 11:04 AM   #3
metgol
metgol is on a distinguished road
metgol's Avatar
2007 AURA XE
1998 SW2
Default
I had a bad bearing and they had to replace the whole hub instead because they couldn't get the bearing out. Which cost a hell of a lot more. Just changing the bearing would be more cost effective.
98 SW2 214000miles
07 Aura 19500miles
/////Alpine inside!
Add to metgol's Reputation
Rate the quality of this post and help metgol reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
metgol is offline
Old 08-22-2004, 02:35 PM   #4
SLeepr
SLeepr's Avatar
Default
Just to update everyone: The front hub DOES NOT include the bearing when purchased from just about everyone I tried. According to the Saturn parts manager, "in his 8 years of working there, he's never seen the hub assemblies include the bearing." However, the rear hub assemblies DO include the bearing.
It does get a little pricey
SLeepr is offline
Old 08-23-2004, 02:13 PM   #5
Qlara
Qlara's Avatar
Default
If you need the stock bearing pre-installed, you need to buy the front knuckle. A part which is connecting the tie-rod, lower ball-joint and the front strut.
Add to Qlara's Reputation
Qlara is offline
Old 08-23-2004, 05:28 PM   #6
elvinrodr
elvinrodr is on a distinguished road
2008 VUE 3.6L
Default
The front bearings press into the knuckle. They will get damaged if they are pressed on wrong. They shouln't be a problem to press out. The hub then presses onto the bearing.
91 SL2M
93 SL2A
Add to elvinrodr's Reputation
Rate the quality of this post and help elvinrodr reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
elvinrodr is offline
Old 08-24-2004, 09:52 AM   #7
eRic 02sc2
eRic 02sc2's Avatar
Default
pressing them out is the fun part. depending on how damaged the wheel bearings are in the knuckle. last time i replaced my front wheel bearings, they were both cracked in half. the ball bearings fell out when we pressed them out. saturn sells the bearings and hubs seperately, but you can get a knuckles with the bearing installed. bring money.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
eRic 02sc2 is offline
Old 08-24-2004, 12:07 PM   #8
Qlara
Qlara's Avatar
Default
Another reminder:
Though you can buy a front knuckle with the bearing pre-installed, you still need to manage to get the 'old' wheel hub out and press it back into the new knuckle.
If you buy the parts from dealer, see if they can press the hub for you free. Just ask and see....
Qlara is offline
Old 08-24-2004, 02:00 PM   #9
eRic 02sc2
eRic 02sc2's Avatar
Default
when I did mine last I replaced the knuckles, bearings and hubs together. both left and right sides. so now I have spare knuckles and hubs with busted wheel bearings in them. at some point I will get the bearings pushed out of the knuckles.
eRic 02sc2
Old 08-24-2004, 10:23 PM   #10
wolfman
wolfman's Avatar
Default
I guess I should have been more clear. On the FRONTS, the KNUCKLE assembly comes WITH the bearings installed, the HUB fits INTO the knuckle assembly and can be reused unless damaged (which it rarely is)
wolfman is offline
Stubborn wheel bearing hub assembly 2005 Vue, help! tkearsey Vue General 50 04-26-2019 11:02 PM
Wheel Bearing Hub Assembly Question sledgehammer777 Relay Tech 3 03-08-2010 11:45 PM
Wheel Bearing/Hub Assembly-Front/Rear dildog S-Series Tech 3 05-23-2007 11:58 AM
front wheel bearing/hub assembly Cowboygrad04 Vue Tech 1 06-25-2006 09:19 PM
Front Wheel Hub/Bearing Assembly JD7 Ion General 2 06-21-2005 05:52 AM
