Old 01-08-2020, 06:41 PM   #1
trainer
trainer is on a distinguished road
Default ball joint & Trans care
95 sc2
will be replacing CV axles on auto TAAT trans.Need to know:
will trans fluid escape when I pull axles out of the transnission diferential seals,any way to prevent?
when have to separate ball joints what sort of care/lube do the joints need me to perform before reinstalling the BJ's. Ifthe joints are working Ok shouldI attempt to replace them anyhow when I have the Joints seperated or can they last 400K miles? I see nO zerk grease fittings on my car's ball Joints so assume they are supposedly 'permanently "lubed?
Will it hurt TAAT trans if it gets run for while half quart low on fluid?
Will it hurt TAAT trans if it gets run half quart overfilled?
ADVICE FROM YOU ALL HAS SAVED MY CAR FROM JY FOR YEARS,GRACIAS!
Add to trainer's Reputation
Rate the quality of this post and help trainer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
trainer is offline   Reply With Quote
Old 01-08-2020, 07:13 PM   #2
Default Re: ball joint & Trans care
If you drain the transmission first, fluid won't leak out. Otherwise it will gush.
When I rebuilt my '99 I didn't replace the control arms. I should have, they don't last forever.
Add to Waiex191's Reputation
Ball Joint How To TombedOrchestra Vue Tech 6 05-08-2016 08:25 PM
'03 Ball Joint Chazberry Vue Tech 0 09-04-2014 04:56 PM
ball joint bmxracerchamp12 Ion Tech 9 10-07-2010 12:26 PM
Ball joint? jviper777 Miscellaneous Tech 19 06-21-2004 10:00 PM
Ball joint? Or not? Rozzwell S-Series General 3 11-13-2003 12:13 AM
