Old 12-20-2019, 07:28 PM   #1
billr
Default Starter gears
Does anybody know the pitch and PA of those?
Add to billr's Reputation
Old 12-20-2019, 10:19 PM   #2
billr
Default Re: Starter gears
Cancel this, I have what I need.
Old 12-21-2019, 05:26 PM   #3
billr
Anybody have an old flex-plate or flywheel they will part with for little-to-no cost? I am mostly after the ring gear, and it doesn't have to be perfect, just usable with no missing teeth. A flex would be better, lighter and less of the "disk" for me to have to machine off.
I am in ZIP 94596, but shipping costs from another area are probably low enough for me to get it long distance.
Yes, I know these can be had from a JY, but not too interested in that route. (time, cost, inconvenience, mud, etc)
Old 12-22-2019, 01:47 AM   #4
colonelhogan44
colonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of light
colonelhogan44's Avatar
I may still have a couple kicking around. Ever get down to Fresno?
MechE - I make things!
EGR ADAPTERS AVAILABLE! $30 "reverse" $40 standard
1998 SL2 (gone, never forgotten)
2005 Volvo S40 T5 AWD
1987 Mercedes 300D
1993 Tracker 4x4
1996 Tracker 4x4
Add to colonelhogan44's Reputation
Rate the quality of this post and help colonelhogan44 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
colonelhogan44 is offline   Reply With Quote
Old 12-22-2019, 12:20 PM   #5
onlinebiker
Heya.. I used to live in Pt Reyes Station back in the mid 1980s. Much fun..
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
01 SC2 x 2 yellow
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Old 12-22-2019, 02:25 PM   #6
billr
CH44,
I don't go that way, and you no longer "commute" up I-5 by Woodland to the Pacific NW, do you? Check and see what you have, shipping should be reasonable if you are willing to bother. I would sent you a check ahead of time so you know you won't get "stiffed". Another possibility is a firm I work with that makes daily runs to Bakersfield; just don't know yet how to do a transfer that would be easy for all.
Old 12-22-2019, 05:39 PM   #7
colonelhogan44
I don't commute anymore. If I recall correctly, we met up and you gave me some spikes spiders. I'll look around and If I can find one, I'll give it to you for the cost of shipping it (probably $10 or so)
1987 Mercedes 300D
1993 Tracker 4x4
1996 Tracker 4x4
Old 12-22-2019, 06:12 PM   #8
billr
OK, keep me advised. Are you in Fresno itself, or "nearby"?
Starter solenoid to Starter motor wire replacement? pocomenomosso Vue General 7 12-27-2016 08:56 PM
New starter, reman starter or junkyard starter? dbbarney S-Series Tech 9 12-20-2016 11:02 AM
2007 Installing Remote Starter. Anything I need to get outside of starter package? shaxs Vue General 8 12-25-2011 04:40 PM
Changed Clutch, Starter won't spin/engage (starter clicks) VolvoDude S-Series Tech 10 10-08-2010 02:47 PM
All gears are forward gears?! banana944 S-Series General 4 02-18-2009 09:51 AM
