Old 08-17-2019, 09:14 PM   #1
jpags729
jpags729 is on a distinguished road
jpags729's Avatar
Default Sway Bar Bushing Replacement
I was watching the richpin Sway Bar Bushing replacement video in anticipation of doing the job on my 1999 Saturn SL2. I purchased both sets of the Moog replacement ones from Rock Auto (lower control arm outer and inner bushings). However, in his video, he did not replace the bushing that connects to the subframe side. I purchased both sets of bushings and was wondering if anyone has ever replaced both and does it involve the need to press out the old bushings and press in the new ones? Thanks! Below are the rock auto links to the bushings:
https://www.rockauto.com/en/moreinfo...357264&jsn=344
(ones not replaced in the video)
https://www.rockauto.com/en/moreinfo...357264&jsn=341
(ones replaced in the video)
richpin's video
https://youtu.be/rmOanLT_gQ0
Current:
1999 Saturn SL2 1.9 "Sophia Loren 2"
2008 Honda Accord EX-L 2.4
1993 Chevy Camaro Z28 5.7
Previous:
2007 Chevy Malibu LS 2.2
2003 Nissan Altima SE 3.5
Add to jpags729's Reputation
Rate the quality of this post and help jpags729 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jpags729 is offline   Reply With Quote
Old 08-17-2019, 11:42 PM   #2
Default Re: Sway Bar Bushing Replacement
Pretty sure it's a light press fit, not like hydraulic press fit but at least a 6" bench vice press fit.
The Moog K5307 is not a sway bar bushing anyway, it's a control arm bushing. Going by what RockAuto lists and will admit to a price on, the ACDELCO 21011235 is the only other front sway bar bushing available.
Old 08-18-2019, 09:36 AM   #3
jpags729
jpags729's Avatar
Thanks for the info! I also bought awhile back this part but haven't put it on yet. (https://www.rockauto.com/en/moreinfo...357264&jsn=331
) - Moog K8763. Is this the actual front sway bar bushing?
I'll let you know how I make out.
Current:
Previous:
Old 08-18-2019, 10:06 AM   #4
macbox
macbox will become famous soon enough
macbox's Avatar
1997 SC2
That is the split-type control arm to sway bar bushing which is much easier to install, you probably won’t need the metal insert. By the looks of it, the Moog K8436 is the press-in type control arm to sway bar bushing. Thirdly, the front sway bar to subframe bushing is a D shape with a split on one side so it can wrap around the sway bar without romoving the bar.
"The Twins"
#4, "Betty" 1995 SC2m, 163K, 400 Miles per quart. Garage queen. Currently in 1000 pieces for a rebuild.
#7 "Betsy" 1995 SC2, 131K, daily driver.
Add to macbox's Reputation
Rate the quality of this post and help macbox reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
macbox is offline   Reply With Quote
Old 08-18-2019, 10:31 AM   #5
ACDELCO 21011235 is for the sway bar to cradle
MOOG K8436 is for the sway bar to control arm
MOOG K8763 is for the sway bar to control arm as well but a different material and includes the washers.
Old 08-19-2019, 06:42 PM   #6
jpags729
jpags729's Avatar
Thanks for the clarification!
Current:
Previous:
Old 08-19-2019, 06:46 PM   #7
jpags729
jpags729's Avatar
So when I got the Moog K8763, I only bought one box, and it came with two blue bushings, two washers, and one tube. Is that for only one side of the car? Have you or anyone on here installed the K8763 and can walk me through it? Is it similar to the process with the K8436 (standard black bushings seen in rich pin's video)? Appreciate the help!
Current:
Previous:
Sway bar bushing replacement? rbar S-Series Tech 10 06-06-2012 10:07 AM
Sway bar bracket bushing replacement rchiarito Ion Tech 1 05-05-2010 08:14 AM
Sway Bar Endlink Bushing Replacement bgsneeze Ion General 3 05-17-2007 12:48 AM
Sway bar bushing replacement 92 Sl johnt671 S-Series Tech 4 09-27-2005 07:57 PM
sway bar bushing replacement SC2fast Miscellaneous Tech 1 01-31-2001 10:10 PM
