Old 03-23-2019, 08:23 AM   #1
mystryda
mystryda is on a distinguished road
Default Engine cradle still good? How to keep it that way?
My engine cradle is rusting. Do you think itís still good? I donít see any holes in it.
If still good, how can I keep it that way or retard the rust on it and the attached parts?
File Type: jpg 1FAD93C1-FC6C-4EC8-B3E5-E9C5A741A173.jpg (127.4 KB, 41 views)
Add to mystryda's Reputation
Rate the quality of this post and help mystryda reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mystryda is offline   Reply With Quote
Old 03-23-2019, 09:02 AM   #2
Waiex191
Waiex191 is a jewel in the roughWaiex191 is a jewel in the roughWaiex191 is a jewel in the roughWaiex191 is a jewel in the rough
Waiex191's Avatar
Default Re: Engine cradle still good? How to keep it that way?
I would say its days are numbered. Mine looked like this when I replaced it:
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 03-23-2019, 09:05 AM   #3
macbox
macbox will become famous soon enough
macbox's Avatar
If it were mine, I'd consider it drivable for a while, but I'd start looking for a better condition cradle from the southern junkyard.
ou can soak the cradle with motor oil to keep it from oxidizing, there are members who soak their cradles once a year. If you do get one from the south, you can paint it with POR-15 to keep it in good condition longer.
"The Twins"
#4, "Betty" 1995 SC2m, 163K, 400 Miles per quart. Garage queen. Currently in 1000 pieces for a rebuild.
#7 "Betsy" 1995 SC2, 131K, daily driver.
Add to macbox's Reputation
Rate the quality of this post and help macbox reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
macbox is offline   Reply With Quote
Old 03-23-2019, 10:57 AM   #4
Kaervak
Kaervak has a spectacular aura aboutKaervak has a spectacular aura about
Kaervak's Avatar
Definitely replace it sooner than later. Where the control arm mounts on the drivers' side looks like mine and when I was removing the control arm to reuse the bolt, that area crumbled to dust. I got my replacement from ebay from a wrecking yard in the pacific northwest, I paid a bit more for mine, but It's completely rust free. Anything I would have pulled locally would have been just like the original.
Add to Kaervak's Reputation
Rate the quality of this post and help Kaervak reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Kaervak is offline   Reply With Quote
Old 03-25-2019, 08:46 AM   #5
SLfun
SLfun will become famous soon enough
2006 ION Red Line
Mine looks the same as yours and I just keep it soaked in rust proofing oil.
I also inspect it 2x a year to make sure it stays safe.
It's been 5 years, no problems, but I am starting to look for a replacement.
The oil is buying me time for sure.
My 96 SL2 and 98 SL1 have joined together to become one. So I guess I now have a 1996/8
SL1-2.
Add to SLfun's Reputation
Rate the quality of this post and help SLfun reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SLfun is offline   Reply With Quote
Old 03-25-2019, 08:54 AM   #6
colonelhogan44
colonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of light
colonelhogan44's Avatar
I've got a nice rust free cradle in my stash of parts. I'm in CA, though, so I'm sure shipping is a pain.
MechE - I make things!
EGR ADAPTERS AVAILABLE! $30 "reverse" $40 standard
1998 SL2 (gone, never forgotten)
2005 Volvo S40 T5 AWD
1987 Mercedes 300D
1993 Tracker 4x4
1996 Tracker 4x4
Add to colonelhogan44's Reputation
Rate the quality of this post and help colonelhogan44 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
colonelhogan44 is offline   Reply With Quote
Old 03-30-2019, 05:33 AM   #7
onlinebiker
I have fixed them with good results. You could probably do the job in place - if you are a good welder. I did mine with TIG welding on the bench. You cut out the bad material and weld in new. Be advised - the construction is of several layersnof steel - and you want to grind back till you are into solid, rust- free material.
To keep it from rusting - just copy the passenger's side - which almost NEVER rusts - by dumping oil all over it. Oil changes get the passenger's side soaked, thus preventing rust out....
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
01 SC2 x 2 yellow
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Will a 2001 DOHC S Series engine cradle/subframe fit my 2002 SL1 with a SOHC engine?? Doug427 S-Series General 3 11-29-2018 12:10 PM
What's a good engine cradle go for$ these days? teamtruett S-Series General 3 02-18-2013 12:09 PM
sw2 engine cradle augey S-Series Tech 3 03-20-2008 06:27 AM
Need engine cradle for 97 SC1 c5f8 S-Series General 9 05-21-2005 02:37 PM
Engine cradle : HELP please ! Maxim S-Series Tech 6 06-20-2002 11:02 PM
