Old 03-06-2019, 09:49 AM   #1
ptofimpact
ptofimpact is on a distinguished road
Default Door Locks Electric
The other day, while sitting in the 1998 Saturn, 4 door , the electric locks, were activating themselves, Seemed to start when the door was opened, both with engine running, and off. Had to pull the 2 Relays to get it to stop.
Any ideas appreciated
Add to ptofimpact's Reputation
Rate the quality of this post and help ptofimpact reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ptofimpact is offline   Reply With Quote
Old 03-06-2019, 10:15 AM   #2
Default Re: Door Locks Electric
Generally it's the driver door lock/unlock switch. Pry it out of the door & disconnect to test.
Old 03-06-2019, 10:46 AM   #3
ptofimpact
Thank you, can you tell me if the door panel need be removed?
Old 03-06-2019, 11:15 AM   #4
Video: https://youtu.be/EhPaxeq4q8w?t=90
Can skip to the beginning by removing the "?t=90" part of the link but it takes the 90 seconds to get to anything useful.
Old 03-06-2019, 11:51 AM   #5
ptofimpact
Thumbs Up Re: Door Locks Electric
Again, Thank you, it helps greatly
Old 03-06-2019, 02:23 PM   #6
colonelhogan44
colonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of light
colonelhogan44's Avatar
If you buy the POS Dorman replacement, be sure to save your old lock to swap the trim over. The Dorman one is often the wrong side and you have to use the original trim piece. It's higher quality anyway, so regardless you'll probably want to use it over the paper thin one that will come with the switch.
MechE - I make things!
EGR ADAPTERS AVAILABLE! $30 "reverse" $40 standard
1998 SL2 (gone, never forgotten)
2005 Volvo S40 T5 AWD
1987 Mercedes 300D
1993 Tracker 4x4
1996 Tracker 4x4
Add to colonelhogan44's Reputation
Rate the quality of this post and help colonelhogan44 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
colonelhogan44 is offline   Reply With Quote
Old 03-06-2019, 08:59 PM   #7
ptofimpact
Thank you Colonel, going to see what NAPA has
Old 03-08-2019, 03:03 PM   #8
ptofimpact
Picked up a switch at NAPA, 10 minutes, problem solved.
Many thanks
Electric door locks don't work... pierrot L-Series Tech 9 11-28-2014 09:45 AM
Electric door locks need disabled on sl2 stadlgi S-Series General 2 03-07-2012 10:38 PM
Strange Electric Door Locks problem keithldick S-Series General 4 06-06-2009 09:15 PM
'98 SW1 - Electric locks going nuts! IGot3 S-Series Tech 3 04-21-2007 08:52 AM
Electric Door Locks sroney S-Series Tech 3 06-18-2006 07:38 PM
