Old 03-06-2019, 12:06 AM   #1
TwoFistedJustic
TwoFistedJustic is a jewel in the roughTwoFistedJustic is a jewel in the roughTwoFistedJustic is a jewel in the rough
Default Is it necessary to replace nuts when doing suspension work?
I'm preparing to replace all the rubber bushings in my gen3 SC2 suspension. The OEM shop manual says that some of the nuts, once removed, must be replaced with new ones.
Is it really necessary?
And where would I get them? Can I just use grade 10.9 from the hardware store?
Add to TwoFistedJustic's Reputation
Rate the quality of this post and help TwoFistedJustic reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TwoFistedJustic is offline   Reply With Quote
Old 03-06-2019, 02:49 AM   #2
colonelhogan44
colonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of light
colonelhogan44's Avatar
Default Re: Is it necessary to replace nuts when doing suspension work?
I never bothered and never had issues. YMMV.
MechE - I make things!
EGR ADAPTERS AVAILABLE! $30 "reverse" $40 standard
1998 SL2 (gone, never forgotten)
2005 Volvo S40 T5 AWD
1987 Mercedes 300D
1993 Tracker 4x4
1996 Tracker 4x4
Add to colonelhogan44's Reputation
Rate the quality of this post and help colonelhogan44 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
colonelhogan44 is offline   Reply With Quote
Old 03-06-2019, 07:16 AM   #3
youstolemybeer
youstolemybeer is on a distinguished road
2001 SW2
if they are Nylocks then its not a bad idea, as for just regular nuts, nope. never had one come loose after suspension work
Add to youstolemybeer's Reputation
Rate the quality of this post and help youstolemybeer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
youstolemybeer is offline   Reply With Quote
Old 03-06-2019, 10:06 AM   #4
bumpdraft
bumpdraft's Avatar
1998 SW2
You do not have to worry about rust. Replace the ones you perceive as critical.
As far as following the shop manual, there is anti-seize on every bolt on my car that is not inside the engine or transmission. I use jamb nuts on a few critical suspension parts. If there is no cotter pin, I re-check torque when Im under there to be sure nothing moved. It never does.
Add to bumpdraft's Reputation
Old 03-06-2019, 01:57 PM   #5
Caterpillar conducted extensive testing in regard to the cotter pins in the rod and main bearing cap nuts. The results were they were completely useless so they were eliminated.This was done in the late 40s-early 50s.
Any prevailing torque nut is a 1 time use nut. The nyloc is usually considered single use but in most cases a re-use is OK. The FSM will identify the specific single use fasteners in the specific repair-replace section.
Old 03-07-2019, 07:16 PM   #6
TwoFistedJustic
In the event that I do need to replace a prevailing torque nut, do you have a good supply source? My FLAPS doesn't carry them.
Old 03-07-2019, 07:44 PM   #7
You usually can find special nuts like axle nuts at the FLAPS and the generic ones from McMater-Carr industrial supply. OR you can recycle the old nut after careful cleaning of the nut and bolt/shaft and using Loctite 272.
Keyless entry doesn't work on drivers side door, horn goes nuts mjollnir79 Ion Tech 5 03-15-2014 08:41 PM
Spindle nuts on drive shafts REPLACE THEM WHEN YOU DO BEARINGS Selsputers S-Series General 5 04-27-2012 06:29 PM
Reverse slam: cost to replace valve body & tighten nuts? DWVANDY S-Series Tech 4 09-30-2009 03:30 PM
Aftermarket Lug Nuts Won't Work The Critic S-Series Tech 13 07-06-2009 11:02 AM
MUST I replace the nuts when adjusting caster? TIMSPEED S-Series Tech 1 10-17-2006 02:54 AM
