Old 12-16-2010, 10:49 PM   #1
Ruger141
Ruger141 is on a distinguished road
2000 SL1
2007 ION-2 Sedan
Dizzy Wheel into a Pole
Hey guys, my fiancee has a '07 Ion and managed to smack the front drivers side wheel into a pole from a stop. She thought it was in reverse, stepped on the gas and it being actually in drive, ran the wheel into the cement bottom of a light pole. (I believe her wheels were turned to the left some when she hit it)
I was only able to take a quick peek at it in the parking lot, the wheel was still on so it was difficult to have a good look but and all I could see was a bent Tie rod. This is one thing I havent had to do yet on a car, but from what I read and what I saw I will have to replace the inner and outer tie rod on that wheel and then an alignment would be next. Is there anything else I should be vigilant of? I am going to do a general look over of everything once I get the tire off tomorrow. Also any tie rods better to get over another brand due to reliability etc? Thanks.
Add to Ruger141's Reputation
Rate the quality of this post and help Ruger141 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Ruger141 is offline   Reply With Quote
Old 12-16-2010, 11:21 PM   #2
2006 ion2
2007 ION-2 Sedan
Default Re: Wheel into a Pole
most suspension parts are only available from chevy/gm/saturn, not too many american deltas need tie rods. honestly, on these cars, for this, there is no reason to go aftermarket.
as far as damage assessment, compare everything on the side she hit to the side she didn't. the front ends on these cars are pretty stout, but if she managed to bend/break the tie rod, make sure. also, make sure the steering rack doesn't have excessive play now. my ions have always had no slop in the wheel.
2007 Saturn Ion 2
2003 Chevrolet venture lt
Add to 2006 ion2's Reputation
Old 12-16-2010, 11:25 PM   #3
Ruger141
2000 SL1
2007 ION-2 Sedan
Well I am doing some more digging currently (I have access to the GM Service Information Website). They do not say how to replace the Inner Tie Rod by itself, only how to replace the Steeing Gear which from what I see is the entire steering housing. BUT...O'Reilly's lists an inner tie rod and an outer tie rod as seperate parts that they stock. Another Tech here at work seems pretty confident that I can replace the inner tie rod by itself. Anyone had to do this that can vouch for that?
Old 12-16-2010, 11:27 PM   #4
Ruger141
2000 SL1
2007 ION-2 Sedan
Thanks 2006, O'reilly lists the inner and outer tie rods for a grand total of $82.99 which seems reasonable enough for me. I'm sure dealer parts would be more than that?
Old 12-16-2010, 11:55 PM   #5
Ruger141
2000 SL1
2007 ION-2 Sedan
By the way, hope you're enjoying all that snow up there I sooo wish I didnt have to sell my sled, but you gotta do what you gotta do if you want to buy a house.
Old 12-17-2010, 12:13 AM   #6
2006 ion2
2007 ION-2 Sedan
you'd be surprised how inexpensive the dealership can be at times. I would definitely think the tie rods would be replaceable separate from the steering assembly. and I love the snow, too bad ions are crap in the snow without winter tires. thankfully I have some.
2007 Saturn Ion 2
Old 12-17-2010, 06:17 PM   #7
Ruger141
2000 SL1
2007 ION-2 Sedan
Well I got the parts and replaced the inner which was bent and the outer which was worn out and was surprised how simple it was. Oreilly's carried Moog and I was very happy with them since they included some loctight and torque specs for the inner which I could not find on the GM site. I had counted how many turns the old outer took to come off and threaded the new on the same amount. The tire is much straighter than it was but still off some in Toe, so an alignment is in order.
I am going to have the Toe done to fix that and have the Camber checked as well. Do Ions even have the option of Caster adjustment?? Dont want to get burned on that if they dont and am charged for it anyways.
Old 12-18-2010, 08:06 AM   #8
2006 ion2
2007 ION-2 Sedan
I'm not 100% sure if it is or isn't.
Old 12-20-2010, 12:21 AM   #9
Greg1
Greg1 will become famous soon enough
Greg1's Avatar
I just did the struts on my stepdaughter's 05 and the camber is readily adjustable but the caster is not.
97 SW2 5-Sp 273k -mine
02 SC2 5-Sp 67k - best friend's
Add to Greg1's Reputation
Rate the quality of this post and help Greg1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Greg1 is online now   Reply With Quote
Old 04-13-2019, 09:44 PM   #10
Ecomike
Ecomike is a glorious beacon of lightEcomike is a glorious beacon of lightEcomike is a glorious beacon of lightEcomike is a glorious beacon of lightEcomike is a glorious beacon of light
Can I get confirmation that Caster on the 2003 Saturn ION is not adjustable?
If it is out, how does one fix a bad caster?
Add to Ecomike's Reputation
Rate the quality of this post and help Ecomike reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Ecomike is offline   Reply With Quote
Old 04-13-2019, 11:12 PM   #11
Caster is not adjustable. Specs below.
04 Vue AWD V6 - Left front wheel clicking noise manually turn wheel when on jack johnnyphive Vue General 14 08-03-2010 08:19 PM
2003 Vue Steering Wheel Tunk Noise When Turning Wheel kencat Vue General 6 03-05-2010 07:06 PM
a 2004 Saturn Vue that hit a utility pole. tominsky Vue General 22 06-03-2006 03:34 PM
Saturn on the POLE KevSC1 General Saturn Discussion 9 09-19-2003 11:09 PM
