Old 10-23-2015, 02:49 PM   #1
SC2by2
SC2by2 is on a distinguished road
Default '97 SC2 heater hose removal for heater core flush
The heater isn't putting out as well as it used to, so I replaced the thermostat (it was the original) since the temp was only about 1/4 on the gauge, and checked the mixing doors which seem to be working.
Checked the heater hoses, and they aren't very equal in temp, so I want to flush the heater core.
On the intake side, the hose clamp is turned in toward the engine to where it's hard to reach. Not sure I can get to it from underneath.
Sorry if this is a dumb question, but what's the best/easiest way to get the hose clamp off?
Add to SC2by2's Reputation
Rate the quality of this post and help SC2by2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SC2by2 is offline   Reply With Quote
Old 10-23-2015, 03:00 PM   #2
blue92
blue92 will become famous soon enoughblue92 will become famous soon enough
1992 SL1
Default Re: '97 SC2 heater hose removal for heater core flush
"intake side" - for the heater core is the short hose coming from the back of the cyl head.
Is this the one your referring to?
When I back flush, I disconnect down by the overflow bottle, pinch the hose using a pair of vise grips, so it can only go backward toward the heater core. Disconnect the short hose mentioned above at the cyl head. turn on the hose and flush till clear.
92 SL1 original owner
94 SL2 Homecoming
98 SC2 White Hot
02 SC2
Add to blue92's Reputation
Rate the quality of this post and help blue92 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
blue92 is offline   Reply With Quote
Old 10-23-2015, 03:20 PM   #3
SC2by2
Yes, it's the closest hose in this pic:
http://s202.photobucket.com/user/ric...rcore.jpg.html
Like the vise grip idea, I'll give it a try.
Old 10-24-2015, 07:03 PM   #4
SC2by2
Well, I was able to get the bottom hose clamp next to the firewall off with pliers, but had to cut the top clamp off with a dremel tool. Just no way to reach those tabs.
Got the core flushed, washed out the coolant tank with dishwasher detergent, got everything back together. Works great, lots of heat now.
Blue92, the vise grip tip worked great, thanks!
2001 L300 Heater Core/Hose Leak aalegrete L-Series Tech 49 02-15-2015 08:10 PM
Heater Core / Hose Quick Connect Clamp Leakage Varagon L-Series Tech 12 05-18-2014 07:14 AM
heater core flush tyler1987 S-Series Tech 3 10-01-2010 03:52 PM
Heater core hose orientation Terribleoneride L-Series Tech 1 08-22-2009 09:58 PM
Heater core inlet hose part number Hiddenlites S-Series Tech 5 06-27-2005 09:18 AM
