Old 08-03-2014, 08:29 PM   #1
VUEmaniac
VUEmaniac is a jewel in the roughVUEmaniac is a jewel in the roughVUEmaniac is a jewel in the roughVUEmaniac is a jewel in the rough
Default missing bolt (metric or SAE?) for PS bracket
The little bracket between the PS pump and the intake manifold on my new-to-me '97 SC2 appears to be missing the bolt on the intake side. Anyone happen to know the length and type of bolt? It appears to be M10-ish size.
Best,
Don't blame a clown for acting like a clown. Ask yourself why YOU keep going to the circus.
Add to VUEmaniac's Reputation
Rate the quality of this post and help VUEmaniac reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
VUEmaniac is offline   Reply With Quote
Old 08-03-2014, 08:32 PM   #2
Default Re: missing bolt (metric or SAE?) for PS bracket
Should be the generic metric and it is a short one. The last one I replaced I measured the hole and cut accordingly.
Old 08-03-2014, 08:47 PM   #3
VUEmaniac
I'm going to revise my guess and say M8 rather than M10.
I'm thinking 1/2" long + washer ought to cover it. I'll just have to play with it to sort out the threads. Thanks 'nuc.
Old 08-03-2014, 09:39 PM   #4
I think the one I used came from the hardware store and ended up at 1/2-3/4" long. It was a trivial task and 8mm sounds about right.
Old 08-04-2014, 10:14 AM   #5
BV22
2002 SC1
If it helps any, a standard M8 hex bolt generally takes a 13 mm wrench.
BV22
2002 SC1 5M
RIP Sept 1 2018
315,344 miles
Add to BV22's Reputation
Old 08-04-2014, 11:43 AM   #6
Uh, someone's confusing hex head size and bolt diameter. 10mm head bolts are generally M6, and the fuel rail bolts along with that ps pump bracket use 8mm head bolts.
http://www.boltdepot.com/fastener-in...head-size.aspx
M14 is the strut->knuckle, cradle->car and rear lateral link->knuckle size (all the same diameter & thread, just varying on length and the stock cradle bolts are more forgiving of miss-alignment).
M8 is the larger A/C bracket bolt size.
M6 is the majority of the timing cover bolt size, about the most common size used on the S-Series.
M5 is probably the size of the bolt you need. Might be a custom M6, but I doubt it.
It's most likely a M5x1.0x13mm bolt, not 100% sure on the 1.0 thread pitch.
Old 08-04-2014, 02:00 PM   #7
VUEmaniac
I found an M8 bolt in my toolbox and it threaded right in. I just need to cut it to size. This threads into a hole on the rib of one of the intake manifold runners and holds a brace for the back of the PS pump.
Old 08-06-2014, 11:20 AM   #8
VUEmaniac
In case anyone hits this thread in the future, the answer is:
M8 x 1.25 x 25mm
Picked one up at my local Home Depot for 50 cents.
Best,
Missing bolt? asharay S-Series General 7 02-23-2014 10:43 AM
Part # for trans bracket bolt?? (or alternate) brokendown S-Series General 2 11-30-2011 11:42 AM
help with bracket to block bolt size azcromntic S-Series Tech 6 03-16-2011 06:38 PM
Am I missing an engine mount bracket bolt? pitbull23 S-Series Tech 2 03-15-2009 02:54 PM
'02 Fuel Filter Bracket Bolt MiSaturn S-Series Tech 2 10-13-2007 09:29 AM
