Old 04-29-2014, 09:13 AM   #1
Pickleperforman
Pickleperforman is on a distinguished road
1993 SL1
Default Cleared out a code 19 and car runs great...Now I have a code 26 93 SL1 automatic.
I have a 26 code blinking after I fix the 19(6x) code. Also, the fan will not shut off on my hvac even though I have the selector turned to off. The cabin fan runs and blows even when sitting still. I was wondering if they were related.
I have replaced the temp sensor because the engine fans are coming on when in diagnostic mode along with the quad circuit fault. I understand that these older cars are pretty simple when it comes to the computer control. The temp sensor is very important to these cars. The wiring looks excellent and my connectors are clean and intact.
Add to Pickleperforman's Reputation
Rate the quality of this post and help Pickleperforman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Pickleperforman is offline   Reply With Quote
Old 04-29-2014, 10:02 AM   #2
screwpid
screwpid is on a distinguished road
1993 SL2
Default Re: Cleared out a code 19 and car runs great...Now I have a code 26 93 SL1 automatic.
differentracing.com/tech_articles/dtc/26.html
Hope that helps. If your fan won't turn off try looking at the relay. I had the same code and it turned out to be my IAT sensor having a bad connection
Add to screwpid's Reputation
Rate the quality of this post and help screwpid reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
screwpid is offline   Reply With Quote
Old 04-29-2014, 10:08 AM   #3
screwpid
1993 SL2
Also if you read the article you will see that when in diagnostics mode the fans must turn on, if they don't then code 26 will be thrown, check and replace your dummy lights first. Make sure the coolant level light trac light and abs light are all working too. The article will help you out alot. Take care of the small stuff first so you don't go spending money
And whenever you are doing anything to something that gets electricity in the car always disconnect the battery. just in case
Old 04-29-2014, 10:15 AM   #4
screwpid
1993 SL2
This was pretty helpful for me too
differentracing.com/tech_articles/diag_info.html
Old 04-29-2014, 11:36 AM   #5
billr
"because the engine fans are coming on when in diagnostic mode"
By "diagnostic mode" do you mean jumpering the sockets in the ALDL connector to get blinky-codes? If so, that is normal, would be no reason to change the ECT sensor. (That was already covered above, just wanted to clarify what "diag mode" was)
Add to billr's Reputation
Old 05-01-2014, 01:06 AM   #6
Pickleperforman
1993 SL1
Yes, when the wires are jumped. I sold the car. They car ran like a champ...
Code 32 Runs well with EGR plugged itsnotme1988 S-Series Tech 25 09-26-2015 10:00 PM
does the computer code have to be cleared bill k S-Series General 4 03-25-2013 01:26 PM
MIL with P0171 code. any ideas would be great AV ION Ion General 7 01-17-2011 09:52 PM
Engine runs fine - SES Code 32 - EGR beerhecht S-Series Tech 3 07-17-2008 09:28 AM
How can an OBII code be cleared? zach S-Series Tech 6 06-29-2005 12:49 AM
