Old 04-18-2014, 04:04 PM   #1
davidsky
davidsky will become famous soon enoughdavidsky will become famous soon enough
2005 ION-1 Sedan
Default Separating resonator from converter pipe
05 ION-1
I bought a Walker resonator and muffler. I was wondering how I separate the resonator pipe from the converter pipe. I ground down what I thought was a nut but nothing came loose.
I have a two bolt flange. (I see some that are three in diagrams)
Member of the Crank Window Club
Add to davidsky's Reputation
Rate the quality of this post and help davidsky reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
davidsky is offline   Reply With Quote
Old 04-18-2014, 05:25 PM   #2
2006 ion2
2007 ION-2 Sedan
Default Re: Separating resonator from converter pipe
There is no separating them without cutting the pipe
2007 Saturn Ion 2
2003 Chevrolet venture lt
Add to 2006 ion2's Reputation
Old 04-18-2014, 09:40 PM   #3
davidsky
2005 ION-1 Sedan
Solved the first problem, I just didn't grind down enough.
Now I have to figure out how to get the new pipe in over the axle.
I might need to borrow taller jack stands to get the angle correct
Old 04-19-2014, 06:07 PM   #4
davidsky
2005 ION-1 Sedan
Got that too, job is done. I took the shock bolt out and that let the suspension drop more so I could fit the pipe through.
While the car was in the air I also replaced the shocks. 117K miles I was a bit behind in that matter.
resonator/intermediate pipe install tips? fetchitfido S-Series Tech 7 04-09-2012 03:44 PM
2000 LS2 V6: replace resonator with pipe? edporch L-Series Tech 1 08-26-2011 06:04 AM
Need new Catalytic converter or just pipe? popoquira S-Series General 9 07-29-2007 09:51 PM
Help - Trouble separating cat from resonator. ProDarwin Miscellaneous Tech 9 07-03-2003 05:21 PM
Resonator pipe price gblizard S-Series General 6 05-21-2003 06:45 PM
