Old 04-17-2014, 11:49 AM   #1
jcumens
jcumens is on a distinguished road
1999 SL1
Default Use Heavier Oil For Older Cars??
My Car: 1999 Saturn SL1
Miles: 260K
Oil usage: 1 Quart per 800 miles
Oil weight according to Manual: 5W-30
I am the original owner.
I have always used the 5W-30. A mechanic told me that he uses heavier oil for older cars.
Your opinions please!!
Thank you for your help.
Add to jcumens's Reputation
Rate the quality of this post and help jcumens reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jcumens is offline   Reply With Quote
Old 04-17-2014, 12:47 PM   #2
colonelhogan44
colonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of light
colonelhogan44's Avatar
Default Re: Use Heavier Oil For Older Cars??
Keep using the 5w-30. That's what the engine was designed for, and it seems to have done you well to this point.
MechE - I make things!
EGR ADAPTERS AVAILABLE! $30 "reverse" $40 standard
1998 SL2 (gone, never forgotten)
2005 Volvo S40 T5 AWD
1987 Mercedes 300D
1993 Tracker 4x4
1996 Tracker 4x4
Add to colonelhogan44's Reputation
Rate the quality of this post and help colonelhogan44 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
colonelhogan44 is offline   Reply With Quote
Old 04-17-2014, 12:57 PM   #3
BV22
2002 SC1
^+1 I once tried 20W-50 in my car and it made no difference in the oil consumption rate. Stick with the manufacturer's recommendation.
BV22
2002 SC1 5M
RIP Sept 1 2018
315,344 miles
Add to BV22's Reputation
Old 04-17-2014, 04:02 PM   #4
Pitcher
Pitcher's Avatar
^ Yep.
Use a quality oil, not high mileage.
Clean or replace the PCV Valve, or put in a fixed orifice one.
Owned 4 other S-Series.
Add to Pitcher's Reputation
Rate the quality of this post and help Pitcher reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 04-17-2014, 09:56 PM   #5
anmasher
anmasher's Avatar
As a very general rule mechanics are ignorant when it comes to oil. Save the xw-40/50 for racing and whatnot, not general daily driving.
Add to anmasher's Reputation
Rate the quality of this post and help anmasher reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 04-17-2014, 11:39 PM   #6
^^^+1 use 5w-30 oil and fixed orifice PCV.
Old 04-18-2014, 03:35 AM   #7
1996SL11.9L
1996SL11.9L's Avatar
2002 SL1
I've been using the Rotella T6 for a few years now...........210,000 and counting
Old 04-18-2014, 08:23 AM   #8
SL19302
SL19302's Avatar
2002 SL1
I have been using the Conventional Rotella 10W30 with no issues.
CHECK YOUR OIL!
Add to SL19302's Reputation
Old 04-18-2014, 08:41 AM   #9
^^^That is still a 30 weight oil. All you are accomplishing is increased engine wear at lower temperatures due to low flow caused by excessively high viscosity for a longer period of time.
Old 04-19-2014, 01:23 PM   #10
stovetop1
stovetop1 has a spectacular aura aboutstovetop1 has a spectacular aura about
mobil 1 start early though using synthetics on older cars can supposedly dislodge sludge and destroy your engine, so if you start synthetic under 150k you're probably good, i've been using synthetic since 60k and at 145 k now and it runs like new..., other wise pennzoil high mileage is actually good for dino I wouldnt use any other high mileage dino stuff, but probably just start at a good clean dino at 260k, high mileage is good if you burn alot of oil.
1 quart per 800 miles is a ton of oil.. I would actually recommend pennzoil high mileage 5w30 i used that on at saturn that burned alot of oil and it calmed it down ALOT. unless you wanna get new piston rings installed
Add to stovetop1's Reputation
Rate the quality of this post and help stovetop1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
stovetop1 is offline   Reply With Quote
Old 04-19-2014, 02:32 PM   #11
colonelhogan44
^^^ is 100% myth.
I switched to synthetic at 185k in my SL2 (mostly due to the oil rebates -- see the sticky thread I started in the general forum to get good oil cheap).
All my cars have been switched over at anywhere to 100 - 200k miles. No issues at all, unless cleaning up the varnish inside of the engine is a bad thing.
1987 Mercedes 300D
1993 Tracker 4x4
1996 Tracker 4x4
Old 04-19-2014, 07:29 PM   #12
Janitor Tzap
Janitor Tzap is on a distinguished road
Janitor Tzap's Avatar
2002 SL1
I've used Amsoil on my previous vehicles, on new and rebuilt engines, and have had good results with it.
I've talked to many mechanic's about using a heavier viscosity oil on a older worn engines.
Most told me it will slow the burning a bit.
But you do have the trade off of more wear during start ups, and harder starting in colder climates.
As for switching from Dino to Synthetic on a 2002 SL1.........
I saw problems with Seals, Head & Oil Pan gaskets that failed.
After I did the switch to Amsoil.
But I can attribute these failures too the fact the SL1 was poorly maintained before I became it's third owner.
jcumens,
Your engine qualifies for a MMO Piston Soak.
wolfman has the procedure on the forum.
Then switch to a Synthetic oil, or stay with Dino oil.
But change your oil & filter every 3K faithfully.
Signed: Janitor Tzap
Add to Janitor Tzap's Reputation
Rate the quality of this post and help Janitor Tzap reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Janitor Tzap is offline   Reply With Quote
Old 04-19-2014, 11:09 PM   #13
westwind999
1999 SW1
I'm not sure there is any concern using a 10W30 VS 5W30 in temperatures above freezing. There is maybe some argument that the 10W30 has fewer viscosity improvers that aren't really needed in warmer temperatures anyway. How excessively high could the viscosity be at 0C or above? I'm sure at -20C or something lower, there might be a concern. I'm thinking about using Rotella 10W30 as my next change, for the summer. I haven't found a factual reason not to.
Old 04-20-2014, 04:27 PM   #14
colonelhogan44
I can tell the difference in the way the 10w-30 flows, even at 75 Degrees when pouring it from a bottle. At 30 or so, it really becomes apparent.
I used 10w-30 for a long while while living in CA, but switched to 5w-30 at some point during that time. Why have any extra wear if it can be avoided?
1987 Mercedes 300D
1993 Tracker 4x4
1996 Tracker 4x4
Old 04-20-2014, 05:32 PM   #15
There are 6 different Rotella oils and they are far from the same formulas.
Old 04-20-2014, 07:42 PM   #16
westwind999
1999 SW1
I haven't decided if I will just use the conventional Rotella T 10W30 or the T5 Synthetic blend. Any reason why one or the other would be any extra wear over say Pennzoil 5W30 yellow bottle, for the summer months?
Old 04-20-2014, 09:49 PM   #17
Those grade numbers represent a range of viscosities. With any non-pao oil formula the base oil is the lighter weight oil and VI improvers are added to make the oil pass the higher grade number. Now what do you think happens to film strength when they get excessively hot? All oil tis to thick to flow correctly until warmed up and it takes longer to get the 10w-30 to flow as compared to the 5w-30. A full synthetic is produced starting with the higher grade number base stock and then additives are used to produce the lower one. I most cases the pao base oil has a sufficiently high VI index that minimal additives are required to produce any given multigrade oil.
Old 04-20-2014, 11:41 PM   #18
Signmaster
And as such a 10w conventional would have less VI than a 5W. At well above freezing temps that most experience in the summer, the cold start viscosity at 50 or 60+ degrees is probably more influenced by the oil type than the base weight.
As for the hot temp, once again it's a swag. The OEM recommendations are for the original tolerances the engine was built to, not the worn tolerances that most cars now have unless they have a fresh rebuild.
Quite a few people run heavier weight oils without any known issues. As for the wear claims, without a lot of data it's just claims. Drive cycles and conditions will probably be the best guide to overall wear. Some will use the best available oils and spend more money avoiding a rebuild. Some will go cheap on oil and pay the extra money in earlier rebuilds.
It's your car.... pick your poison.
Old 04-21-2014, 06:12 PM   #19
For anyone who actually cares go look up your favorite brands of oil and then look at the available grades in each product line. Each product line has a different base oil. You will find some that have 0w-30, 5w-30, and 10w-30 in a single product line but not many.
Old 04-22-2014, 02:05 AM   #20
hooked2u
hooked2u is on a distinguished road
1999 Saturn SC2 4 speed automatic. My owner's manual recommends 10W-40. I've always been a Valvoline guy. Around 185k I noticed puffs of smoke coming out of my tailpipe. I never had to add oil prior to this between oil changes. I mentioned this to my mechanic and was asked how often I had to replace oil? I told him about every 800 miles I had to add one quart. He recommended that I run Synthetic Mobil 10W-30 in warm weather and 5W-30 in cold weather.
Around 192K miles I began using one quart every 300-400 miles of interstate driving, less when driving city streets. I happened to mention this to my barber who is a rodder and biker. He recommended I go to 30 SAE. As the oil burning became more steady it was suggested I used 50 SAE motorcycle oil during warm months and 30 SAE during winter driving.
If I can pickup a 2nd car, I will park my 99 SC2, and attempt a ring job or have a pro fix it.
<<1999 Saturn SC2 4 speed automatic. 262,658 (as of: 2014AUG29), low comp cyl#3, parked, use emergency trans. only; 2001 Saturn SC2 5 gear manual. < 127K mi, purch May 2014. Great MPG!>>
Add to hooked2u's Reputation
Rate the quality of this post and help hooked2u reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hooked2u is offline   Reply With Quote
E85 useable in older cars? foo S-Series General 7 06-05-2008 12:20 AM
Using 14" or 15" rims from older ION on 2006 ION QC -what older rims will fit ? ws6formula Ion General 11 12-26-2007 05:35 PM
December 1st 95 and older Calif cars will be evap tested Ron2002SaturnSL S-Series Tech 19 10-30-2007 07:39 PM
Older cars = no more parts.... FL_SL2 S-Series General 21 08-25-2006 07:45 AM
Use a heavier oil this summer? 98greenSC2 S-Series Tech 11 05-25-2005 02:28 PM
