Old 12-30-2013, 12:04 AM   #1
Jeffjuice
Jeffjuice is on a distinguished road
Default Not charging 96 sl2
I've replaced my alternator and tensioner cked voltage from back of alt to starter and only have 11.97 volts running or not.. Car will start and idle fine when I drive it all the lights gon dim air bag light comes on and brake light comes on and the lights go dim each time I hit the gas.. I have power on each side of the fusible link from alt to starter.. Just at a loss.. Since changing the alt the car squeals constantly now sound like power steering pump that's another curve ball it use to only do it when I first started the car then would stop when warmed up.. Any help will be greatly appreciated thanks..
Add to Jeffjuice's Reputation
Rate the quality of this post and help Jeffjuice reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jeffjuice is offline   Reply With Quote
Old 12-30-2013, 12:54 AM   #2
Default Re: Not charging 96 sl2
The squeal is your belt slipping, replace it. With the key on and engine off do you have 12v to ground on the 2 small wires to the side of the alternator?
charging a/c '97 sl1 dddaaa S-Series Tech 10 05-24-2013 01:03 PM
Not charging. GOF Vue Tech 6 11-26-2011 04:35 PM
charging ac mjoekingz28 S-Series Tech 1 08-19-2009 04:00 PM
Charging a/c ..... ii311hive S-Series Tech 12 06-22-2009 05:09 PM
SL1 Battery charging turtledawn S-Series General 14 12-09-2005 08:52 PM
