Old 12-16-2013, 12:33 PM   #1
97blueSL2
97blueSL2 is on a distinguished road
Default SL2 #3 cylinder misfire
Hey everyone, new member but have been a lurker for awhile. I'll try to keep this short but, I've suspected a misfire for a while since the car would drive normal but when taking it out of gear the RPM's would stumble for few seconds then recover. This went on for a year or so. It cleared up in the summer, but with winter it got worse to the point of stalling. MIL light came on with a P0303. Pulled the plugs and #3 was defiantly junk. The others were perfect. Plugs are AC Delcos with only 20K on them. Furthermore found the #3 post on the coil to be heavily corroded to the point it was deformed. So plugs, wireset, and a new 2/3 coil. Still have the same issue. Rough idle, exhaust reeks of unburned fuel so I don't believe its fuel related. I plan to so a compression test once I can obtain the tester, does anyone have a tip on how to test the ignition control module. Anything else I may have missed/overlooked. I'm sure there's a few. Since the issue came on slowly over time I haven't ruled out piston/valve failure. Thanks for your your help.
1997 SL2 5 speed, 257,057....might be waving the white flag.
Add to 97blueSL2's Reputation
Rate the quality of this post and help 97blueSL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
97blueSL2 is offline   Reply With Quote
Old 12-16-2013, 12:39 PM   #2
SL19302
SL19302's Avatar
2002 SL1
Default Re: SL2 #3 cylinder misfire
I would do the compression test like you plan and being the engine appears to have a rich condition have you ever replaced or inspected the Coolant Temp Sensor for cracking and coolant leakage into the connector? Do these checks before going after the ICM module. Its possible if your engine was running rich for awhile like you suspect it caused one of the exhaust valves to burn on Cyl 3.
CHECK YOUR OIL!
Add to SL19302's Reputation
Old 12-16-2013, 12:53 PM   #3
97blueSL2
I've had the car about 2 years and I suspect the ECTS hasn't been touched. The previous owner was a bit of a hack, no telling what he did prior. I don't think its running rich since the other 3 plugs looked normal. ( light tan color) The #3 was completely black. Even after installing the new plugs, wire and coil I ran it for a min, pullled them again, the #3 was wet with fuel, the rest, fine. Wouldn't a lean condition burn a valve, not a rich? Also want to get a wire tester to see if its firing.
Old 12-16-2013, 02:14 PM   #4
SL19302
SL19302's Avatar
2002 SL1
I would check for spark on that Cylinder and most of all do a compression test, That Cylinder is definatly having a problem, Weather it be a spark problem or a mechanical problem.
CHECK YOUR OIL!
Old 12-16-2013, 05:19 PM   #5
97blueSL2
Thanks, I'll let you know what I find. it'll be a few days till I get to it.
Cylinder Misfire Again danf51 L-Series General 4 08-08-2012 12:47 AM
Cylinder 3 Misfire 96GSL1 S-Series Tech 6 06-13-2007 08:45 PM
Misfire cylinder#3 solo1279 S-Series Tech 6 11-08-2005 08:50 PM
3.5L cylinder 5 misfire bluesl2 Vue Tech 2 08-11-2005 11:14 PM
cylinder one misfire kevjt S-Series General 7 02-23-2004 09:01 AM
