Old 12-01-2013, 07:10 PM   #1
nyko46
nyko46 is on a distinguished road
Default SL 2 Transmission Not Shifting
My 1998 Saturn does not shift from park when engine is cold.
During summer time it was not a major issue because as summer in Texas is very hot I needed to just wait few minutes to shift from park to drive or reverse and the carwas just ready to drive.
Now that the winter started, in order to get the car ready to drive, it take me from 13 to 15 minutes to be able to move the lever from park and get the car moving.
As the car have this problem I usually live the engine running in idle in my garage while I take my breakfast before go to work. At the time to leave my work to come homeit takes longer because the car is not in the garage but exposed to the cold air in the parking lot.
Please help me to resolve this issue because I need the car to go to work.
Thanks
Add to nyko46's Reputation
Rate the quality of this post and help nyko46 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
nyko46 is offline   Reply With Quote
Old 12-01-2013, 07:21 PM   #2
billr
Default Re: SL 2 Transmission Not Shifting
Are you saying you can't even move the lever out of P, or that it can move, but trans won't go into gear?
Add to billr's Reputation
Old 12-01-2013, 08:02 PM   #3
nyko46
That is correct; I can not shift from P to D or any other gear unless engine is hot. After lever is out the P position transmission works fine
Old 04-12-2014, 01:05 AM   #4
timspeedII
timspeedII has a spectacular aura abouttimspeedII has a spectacular aura about
TY for this I know someone that has same issue.
Add to timspeedII's Reputation
Rate the quality of this post and help timspeedII reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
timspeedII is offline   Reply With Quote
Old 04-12-2014, 01:07 AM   #5
timspeedII
did u get an answer ?
Old 04-12-2014, 10:19 AM   #6
billr
It is pretty easy to remove that shift arm from the trans shaft. I would first do that, when the engine/trans is cold and can't be shifted. Try moving the trans shaft with a small wrench, and moving the cabin shift lever. That will tell you whether the problem is in the trans or the shift lever/cable; cut the possibilities about in half...
Edit: My '95 doesn't have any kind of "lock-out" to prevent shifting out of P until the brake is applied; but perhaps a '98 does???
Old 04-19-2014, 04:03 AM   #7
timspeedII
Well what it does they say is: In the morning or evening when the engine is cold at 1st start up of the day usually just after start up they attempt to shift into reverse & they say it will not move for a few minutes once the engine warms up some there is no problem. It seems it may be the input/output shaft nut perhaps?
TY for the response.
Old 04-19-2014, 08:00 AM   #8
hooked2u
hooked2u is on a distinguished road
Is your vehicle parked on a level surface? Do you engage the e-brake prior to shifting to park? When was the last time your transmission fluid was changed?
If you consistently shift into Park, not enabling your e-brake, whether on a level surface or incline, I would suspect that over time (19 years in your case) that the transmission lockout pin may be worn. If you've surpassed the changing of the transmission fluid interval perhaps the transmission fluid is too thick to perform properly.
Your 95 is a Gen 1 so it greatly differs from Gen 2 1999 SC2. I have never had the problem you express. Prior to 4 years ago my SC2 was always housed in a non-heated garage. I never warm the engine at idle greater than 1 minute before driving off. I change the transmission fluid at scheduled periods. I always engage the e-brake prior to shifting to Park. I live in a much colder climate than you, northeast Ohio, where temperature extremes are much colder in winter than in Texas.
Surely you should consult with a transmission specialist, IMO.
<<1999 Saturn SC2 4 speed automatic. 262,658 (as of: 2014AUG29), low comp cyl#3, parked, use emergency trans. only; 2001 Saturn SC2 5 gear manual. < 127K mi, purch May 2014. Great MPG!>>
Add to hooked2u's Reputation
Rate the quality of this post and help hooked2u reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hooked2u is offline   Reply With Quote
SL 2 Transmission Not Shifting nyko46 Community Center 1 11-27-2013 02:27 AM
Transmission Not Shifting blove33 S-Series Tech 0 05-28-2012 02:58 PM
Transmission Shifting Anavel S-Series Tech 10 01-26-2009 12:30 PM
Transmission not shifting 94 SL2 modofac S-Series General 0 10-09-2007 10:13 PM
04 V-6 VUE, Transmission Shifting ? aggie04VUE Vue General 17 11-13-2004 02:03 PM
