Old 08-16-2013, 11:49 PM   #1
Chachski90
Chachski90 is on a distinguished road
Default ODOM light isn't lighting up
the odom in my 98' saturn sl2 isn't lighting up but the dash is. it's annoying me that i cant figure out how to fix that! anyone have an idea to try?
Add to Chachski90's Reputation
Rate the quality of this post and help Chachski90 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Chachski90 is offline   Reply With Quote
Old 08-17-2013, 11:34 AM   #2
01SuperCoupe
01SuperCoupe is on a distinguished road
2009 Astra XR
Default Re: ODOM light isn't lighting up
That's an easy fix, although it's a PITA to do it.
You have to remove the dash pad, (2 screws above the glovebox) the the instrument cluster and replace the bulb for the odometer. It's the same bulb as the rest of the cluster bulbs, and I would advise that you replace them all while you're at it...You know as soon as you replace the odo bulb and put it all back together the other bulbs will burn out.
When in stressful situations look to man's best friend for the best advice: "If you can't eat it and you can't play with it, just pee on it and walk away."
Add to 01SuperCoupe's Reputation
Rate the quality of this post and help 01SuperCoupe reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
01SuperCoupe is offline   Reply With Quote
Old 08-17-2013, 01:01 PM   #3
colonelhogan44
colonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of light
colonelhogan44's Avatar
You need to drop the column in the '98 to get that instrument cluster out.
There should be several unused bulbs (abs, back tailgate, traction control, ect) Just swap those into the most used lights (odometer and daytime running light indicator)
MechE - I make things!
EGR ADAPTERS AVAILABLE! $30 "reverse" $40 standard
1998 SL2 (gone, never forgotten)
2005 Volvo S40 T5 AWD
1987 Mercedes 300D
1993 Tracker 4x4
1996 Tracker 4x4
Add to colonelhogan44's Reputation
Rate the quality of this post and help colonelhogan44 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
colonelhogan44 is offline   Reply With Quote
Old 08-18-2013, 09:02 AM   #4
^ ^ ^ what colonelhogan said - 98 is 2nd gen.
Directions from the FSM
http://www.differentracing.com/tech_...99cluster.html
Video How to by richpin for removing the cluster
http://www.youtube.com/watch?v=6jXiwgm3bPg
pic of back of cluster
http://www.saturnfans.com/forums/sho...d.php?t=154888
Old 08-18-2013, 09:15 AM   #5
Is '98 any different than '95-'97 for this? For the extra effort needed to get the column lowered I find it easier and faster to not bother.
Just pull the bezel off the cluster, worm it out, then do the same with the cluster while being careful to not put too much pressure on the odometer button.
Wish I had a video camera to show how I do it...
Old 08-18-2013, 10:08 AM   #6
Take out the left bolt and back the right one off until almost out.
Lighting AQuinn19 Ion Mods 7 02-16-2011 11:53 PM
lighting q's dorisSL S-Series Mods 3 09-06-2008 07:49 AM
Lighting ezera1979 Ion General 6 03-26-2004 12:00 AM
HID Lighting Sam96SL2 Mods and Performance 0 02-15-2001 02:05 AM
Lighting trans4mer S-Series Tech 2 11-13-2000 10:58 AM
