Old 04-13-2013, 05:33 PM   #1
cbrguy
cbrguy is on a distinguished road
cbrguy's Avatar
Default 1997 SL2 - massive oil leak
The oil leak in my 1997 SL2 is massive. I lose about 1 1/2 to 2 quarts every 100 miles. When I stop driving and park it, there is a 12" puddle under the car when I return. The entire underside of the car is coated in oil. I can't continue to drive this car and I need some input as to what might be causing it.
It appears to be leaking at or near the oil pan. My fear is that it is the rear main.
Pictures:
Video:
It appears to be streaming from the oil pan area, but I am thinking it's the rear main?
http://youtu.be/mYBOw8f_UCs
04/17/13 2001 SC2 A, Blue
170k/171k 5/6/2013, burnt valves
06/30/12 1997 SL2 M, Red - parked
215k
10/29/11 1999 SL2 A, Blue
266k
12/09/12 2001 SL2 A, White
200k RIP
Add to cbrguy's Reputation
Rate the quality of this post and help cbrguy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cbrguy is offline   Reply With Quote
Old 04-13-2013, 05:53 PM   #2
Default Re: 1997 SL2 - massive oil leak
Oil tends to leak down... so start at the top, esp around the back of the cam/valve cover, wipe with clean paper towel or toilet paper, work your way down
Old 04-13-2013, 06:49 PM   #3
cbrguy
cbrguy's Avatar
Yeah, I did wipe it down. There are other areas that are damp with oil from a slightly leaking valve cover and me spilling it when I top off.
I was under the car with it running and the oil is a constant stream from that one spot. It drips down onto a bracket and the exhaust.
^^^I left that part out.
I am just having a difficult time believing that all this oil is coming from a pan gasket. Could it be?
215k
266k
200k RIP
Old 04-13-2013, 07:38 PM   #4
Are those two pictures of the cv joints with leaking possibly from a cvj seal?
Old 04-13-2013, 08:05 PM   #5
Anyone else think the oil pan is bent? Looks like more than the "normal" curve of the pan in that area (first pic).
Old 04-13-2013, 09:53 PM   #6
el diablo viejo
el diablo viejo's Avatar
1994 SW1
Please do not take offense, but have you checked the oil filter ?
97 sl2 a/t 104 K
Add to el diablo viejo's Reputation
Rate the quality of this post and help el diablo viejo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 04-14-2013, 12:29 AM   #7
cbrguy
cbrguy's Avatar
Oil filter is dry. Not offended!
215k
266k
200k RIP
Old 04-14-2013, 12:47 AM   #8
cbrguy
cbrguy's Avatar
What I have decided to do is mothball the car for now because I need a daily driver ASAP not a project.
Tomorrow I look at a 1992 SL2 with 157k on the clock. They are asking $1000 and if it drives OK I will buy it.
Then I will pull the engine out of the 97 and rebuild it. I was wanting to do that anyway. I plan was to get another engine, rebuild that and then do the swap. Looks like my plans have changed!
215k
266k
200k RIP
Old 04-17-2013, 11:10 AM   #9
eric888
eric888 is on a distinguished road
1999 SL1
I had a lot of trouble finding a leak last year after my fiance got her oil changed at a Goodyear shop. I told her to take it back. They swore it was an oil pan gasket and barely looked at it. I wiped everything down as much as I could and noticed a small seeping area at the base of the filter. I took the filter off, wiped everything, put it back on and it still leaked. I bought a new filter and the leak stopped. I wouldn't have seen it had I not jacked up the car, took off the wheel and watched it very slowly drip from the base of the filter with a flashlight pointed at it. I change her oil now. They misdiagnosed another issue as well with extremely little effort, so needless to say, no more Goodyear.
Add to eric888's Reputation
Rate the quality of this post and help eric888 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
eric888 is offline   Reply With Quote
Old 04-17-2013, 12:15 PM   #10
Yep - there is no oil pan gasket; just RTV
Old 04-17-2013, 05:11 PM   #11
blue92
blue92 will become famous soon enoughblue92 will become famous soon enough
1992 SL1
Ya, it does look bent to me also. Like someone tried prying it apart.
92 SL1 original owner
94 SL2 Homecoming
98 SC2 White Hot
02 SC2
Add to blue92's Reputation
Rate the quality of this post and help blue92 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
blue92 is offline   Reply With Quote
massive oil leak jstephens L-Series Tech 33 11-02-2012 12:15 AM
Massive oil leak mechanic380 L-Series Tech 3 02-29-2012 08:44 PM
Massive oil consumption, trans leak- wits end! Ryan from Ohio S-Series Tech 3 10-05-2007 06:31 PM
Massive oil leak on startup thefishin6 L-Series Tech 7 11-06-2006 01:10 PM
Massive corrosion, massive problem. Luigi Mario S-Series General 10 06-03-2006 11:21 PM
