Old 05-25-2012, 02:00 PM   #1
Dave The Barbar
Dave The Barbar is on a distinguished road
2000 SL2
Default It's Decision Time
I just lost reverse on my 2001 SC2 auto - rebuilt trans 2 years ago and the warranty is expired. I had reverse slam for a couple of weeks and had a shop appointment for next Thursday.. I am using a quart of oil every 200 miles. Until the trans went, I was thinking about a rebuilt engine and giving the car to my daughter as a graduation gift. Her first car - for college... a three hour drive from home.
But since I don't have a shop, I don't do much of my own work and I don't have money to spend. So do I fix it or replace it - oh, my wife's 2000 SL2 has 210,000 miles and the same oil problem.
A question I have is about a rebuilt engine. Is there a fix for the oil ring issue that causes the oil consumption or will it happen again?
Add to Dave The Barbar's Reputation
Rate the quality of this post and help Dave The Barbar reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dave The Barbar is offline   Reply With Quote
Old 05-25-2012, 02:05 PM   #2
ssewall
ssewall is on a distinguished road
Default Re: It's Decision Time
Drilling return holes in the piston's oil ring groove should solve the sticky rings issue. Before replacing or rebuilding an engine you can attempt the MMO piston soak, which may or may not help.
You shouldn't need to replace the whole trans if all you have is reverse slam. Replacing the valve body with a rebuilt one with the Sonnax update should solve the problem once and for all. You can find these on ebay, also SF member "Special Forces" provides rebuilt valve bodies. Reverse slam that has been let go for too long can damage the friction material in the trans however, which would require a rebuild or replacement.
Add to ssewall's Reputation
Rate the quality of this post and help ssewall reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ssewall is offline   Reply With Quote
Old 05-25-2012, 02:40 PM   #3
Dave The Barbar
2000 SL2
Yeah, I hoped I had caught the slam early- I noticed it a few weeks ago, but reverse is completely gone.
I don't have the tools to do the engine myself and my garage(an old carriage house) has a dirt floor.
Old 05-25-2012, 03:15 PM   #4
PurdueGuy
PurdueGuy's Avatar
1999 SC1
If you don't mind driving stick, a manual swap is a pretty solid fix for the reverse slam issue, though I wouldn't even bother trying to ask a shop to do it. It's very easy, I wonder if there might be an experienced member on this forum that could help you out with some hands-on work at a reasonable fee.
SaturnSeries.net owner
Add to PurdueGuy's Reputation
Old 05-25-2012, 03:53 PM   #5
I don't have an auto trans, so I don't really pay much attention to what I see here about fixing auto transmissions - but I recall seeing references to losing reverse beging fixed by retorquing an input (?) shaft nut. Might be worth searching on - and asking a friend/relative if you can borrow their garage (with concrete floor ) for a weekend
IIRC, you need a thin-walled 23mm socket? Search will get some definite answers
edit: found a How To
http://www.saturnfans.com/forums/sho....php?t=112858#
Crankshaft Decision Time Ramics S-Series Tech 17 02-11-2012 03:50 PM
A decision... ironnerd88 S-Series General 21 09-27-2010 01:48 PM
Decision time for the SW1 _alez_ S-Series General 4 09-21-2007 10:13 PM
Decision Time SailFan Vue General 12 04-22-2004 06:51 PM
Decision Time: Bad cylinder head / gasket? Richbo S-Series Tech 1 03-15-2003 01:21 AM
